A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Picking up a 2006 Audi A6 3.2
Old 05-06-2014, 09:37 AM
  #41
ProtoFly's Avatar
Kevin, I think now that the timing components are done (presumably with the updated parts), you will be good for another 120k miles at least.
My A6 has 165k miles, and I've just done the timing components (and a bunch of other stuff), similar to what Kevin had done. Probably 4k in parts, including the new Xenon AFS headlight (stupid expensive headlight!) that I had to replace due to the high-beam shutter not working.
Anyway, I still love my car. Even though it isn't necessarily cheap to fix. Since I do my own work (yes, even the engine pull for the timing guides and tensioners), I only concern myself with the price of parts. Audi is odd, as some things which you expect to be expensive aren't, and things which should be inexpensive aren't as well.
-Darryl
Originally Posted by KevinGary
I have not updated the list recently because the car has been at the dealership for 33 out of the last 38 days. Despite changing the oil every 5k miles and the ATF every 40k miles, the timing chain guides and tensioners, as well as the torque converter, all failed. I love the car but I am considering getting a 2015 RS7 as my daily driver and relegating the 2005 to snow car status. I have also been very impressed with the A6 TDI that I have had as a loaner for the last month. Of course my wife and daughters will tell you that I will never get rid of my pampered old car.
Old 05-06-2014, 09:55 AM
  #42
raj99's Avatar
Raj,
Should I give him the laundry list or just the $16k list for the items done between 133k miles and 138k miles?
Kev
Hi Kev,
Well that list should be a <b>sticky</b> on this forum
BTW, when you get the RS7, I want to see pics...those are absolutely lovely cars. I have a neighbor who has one and it looks good from every angle!
The 4.2 would make a great winter car. But the newer diesels are great and the interiors are certainly refreshed.
Old 05-09-2014, 06:14 AM
  #43
KevinGary's Avatar
I have an 05 4.2 that I purchased new 9 years ago. She currently has 139k on the odometer. As far as reliability, she is ok, but she is no Lexus. But she is a lot of fun to drive. I recently reviewed most of the service records on my car and have put together a list of the service, maintenance and repair records. I believe this list will help show others the problem areas that I have experienced over the years and show what maintenance items to expect as our cars get older and have higher mileage. You should understand that I can be a bit crazy when it comes to my old car and that I want everything to continue to perform as it did when the car left the factory floor.
Miles Service
884 Miles
1) MMI hardware replaced
5,283 Miles
1) 5,000 mile service
10,152 Miles
1) Oil Change
14,775 Miles
1) 15,000 mile service
2) tighten front passenger seat
3) tighten air vent outlets
4) update airbag software
5) tighten dashboard
6) update Mmi software
20,059 Miles
1) Oil Change
2) tighten dashboard
20,685 Miles
1) Replaced pollen filter door
2) Replace tire pressure sensor
3) Replace Mmi control ****
24,727 Miles
1) 25,000 mile service
3) replace windshield wiper blades
28,506 Miles
1) Brake fluid flush
2) Repair front passenger seat frame
3) Replace license plate light bulb
4) Update MMI software
5) Repair ski sack
6) oil change
28,620 Miles
1) Replace all 8 coil packs
2) Replace throttle control valve
29,806 Miles
1) replace fuel door cover
2) update airbag software
32,254 Miles
1) Replace front brake pads
2) clean HVAC drains
3) replace pollen filter
33,926 Miles
1) Replace rear brake pads
2) Replace fuel filter
3) Lube steering column
4) Tighten dashboard
5) 35,000 mile service
36,129 Miles
1) Update fuel gauge software
2) Replaced power steering hose clamp
36,739 Miles
1) Replace interior light in driver's footwell
37,715 Miles
1) Update airbag software
40,759 Miles
1) Transmission fluid flush
2) Replace fluids in differentials
3) oil change
44,754 Miles
1) Replace steering column
2) convert front brake pads
3) 45,000 mile service
49,419 Miles
1) Replace head cover gasket
2) Oil Change
50,283 Miles
1) Replaced rear sunshade motor
54,659 Miles
1) coolant system flush
2) replace coolant temperature sensor
3) replace fog lamp
4) replace trunk latch
5) 55,000 mile service
56,440 Miles
1) update ECU module
2) replace tire air pressure sensors
3) replace windshield wipers
60,168 Miles
1) oil change
2) brake fluid flush
3) replace rear seat air bag ignitor
61,040 Miles
1) replace front brake pads and rotors
2) replace rear brake pads and rotors
65,209 Miles
1) 65,000 mile service
3) replace parktronic speaker
65,635 Miles
1) replace thermostat
66,553 Miles
1) Replace light bar in front passenger door
66,848 Miles
1) Replace wood trim on driver's front door
69,020 Miles
1) Oil change
70,741 Miles
1) Replace rear right tail light assembly
2) Clear air bag codes
75,099 Miles
1) 75,000 mile service
75,762 Miles
1) replace center rear seat air bag sensor
2) replace rear seat bracket
80,187 Miles
1) oil change
2) flush transmission fluid
3) replace brake fluid
85,450 Miles
1) 85,000 mile service
87,879 Miles
1) replace rear seat air bag sensor connector
2) readapt tilt wheel steering column
90,746 Miles
1) oil change
2) replace oil pressure sensor
3) re-adapt steering column
4) replace rear brake pads and rotors
93,793 Miles
2) replace front brake pads
95,964 Miles
1) 95,000 mile service
2) replace battery
100,600 Miles
1) oil change
2) replace all 8 coil packs
3) replace fuel filter
4) replace brake fluid
5) coolant flush
6) replace supplemental rear passenger air bag
103,924 Miles
1) 105,000 mile service
2) replace passenger tailight assembly
3) replace right side motor mount
110,515 Miles
1) oil change
2) replace all 4 upper control arms
3) replace both side sway bar links
115,704 Miles
1) 115,000 mile service
2) 4 wheel alignment
3) replaced left side license plate bulb
4) replaced passenger side running light
120,490 Miles
1) oil change
2) replace transmission fluid
3) replace differential fluids
124,683 Miles
1) 125,000 mile service
2) replaced front brake pads and rotors
3) replaced rear brake pads
4) replaced satelite radio module
5) replaced battery
127,496 Miles
1) replaced rear passenger window regulator
2) replace passenger sider amber light bulb
133,383 Miles
1) replace jet pump valve
2) replace engine temperature sensor
3) replace both radiator hoses
4) coolant flush
5) brake fluid flush
6) 135,000 mile service
133,600 Miles
1) replace right side combi valve
2) replace passenger side adaptive headlight assembly
133,714 Miles
1) fuel injection service
134,585 Miles
1) replace vacuum line under manifold
2) replace temperature sensor
3) replace driver side adaptive headlight assembly
135,880 Miles
1) replaced thermostat
2) bled coolant system
3) replaced rear passenger side seat latch
137,015 Miles
1) replace drivers air bag
2) replace wiper blades
138,250 Miles
1) replaced radiator
138,682 Miles
1) oil change
2) replace torque converter
3) replace timing chains
4) replace timing chain guides
5) replace timing chain tensioners
davparf
Q5/SQ5 MKI (8R) Discussion
38
09-30-2020 05:01 PM
bballfreak
9
04-14-2019 06:59 PM
Kerry G
05-18-2018 06:12 AM
AndyinMN
11
03-30-2018 08:18 PM
2005audia6
09-08-2015 11:54 AM
Quick Reply: Picking up a 2006 Audi A6 3.2
