Sponsored by:
Sponsored by:
need help audi a8 3.0 tdi d3 2004 limp mode !!!!
Old 11-28-2014, 10:10 AM
bornau's Avatar
Default need help audi a8 3.0 tdi d3 2004 limp mode !!!!
i have a problem with my audi a8. flashing glow pulg light and car goes in to limp mode.
i changed the turbo actuator and was working ok for a week the gone again.
i switch ignition off then back on and light gone car working fine again msybe for a day 2,3, maybe for an hour.
the erroes im gettin are
Diesel (BNG - TDI - MT/AT)
DTC Description
19804 - Boost control circuit, electrical malfunction
- Intermittent
- Intermittent
19591 - Variable intake manifold, switchover valve; lower stop not reached
p0243- turbocharger/supercharger wastegate solenoid A
p0048- turbocharger/supercharger boost control solenoid A circuit range/performance
Old 11-28-2014, 02:16 PM
Mister Bally's Avatar
Use standard automotive electrical troubleshooting techniques to trace and verify those two malfunctioning circuits. Since two circuits are unlikely to go bad at once, lokk for a loose or disconnected connector.
Old 11-28-2014, 02:31 PM
haggisuk's Avatar
I'm going to go with the carbon build up on this one. there is two faults mention the limits were not reached.
If you are capable on the spanners, have a go at de coke on the turbo and see what you find.
Old 11-29-2014, 01:39 PM
bornau's Avatar
Thanx guys yes i do fix my cars usualy well where i can.i did clean throttle body check loose conections.all fine.il go at the turbo and manyfolds next i let u know anything new
This is what someone wrote me but i dont know exactly does he means and what part to look for .....:
Yeah, the solenoid theat operates the wastegate on your turbo must be shagged. The wastegate is a valve that bypasses exhaust gasses to further back in the exhaust, past the turbocharger. The wastegate regulates how much exhaust gas goes through your turbocharger which in turn regulates how much boost (positive pressure) the turbocharger produces and forces into the the cylinders. It should be a fairly easy and cheap fix. A lot easier and cheaper than a turbocharger replacement :-)
Old 12-01-2014, 02:42 PM
bornau's Avatar
Anymore ideas?
Old 12-01-2014, 03:24 PM
MP4.2+6.0's Avatar
Default Not really the right board; 98% of posters have petrol
Welcome BTW.
Unfortunately in your case this is basically a North America board as far as poster knowledge. A few post from the UK and Continental Europe. Almost everyone has a gas motor D3, and TDI's weren't sold here until the D4. If there are any decent boards in the UK, I would try there (assuming your Deutsch is no better than mine). You could also try the Q7 board here, since that has had the longest running 3.0TDI install here in North America, and a fair number are out there.
Feel free to hang out, and we're probably more help for most anything else on a D3.
gh0st
01-19-2008 04:43 PM
BoostedA4Quattro
04-04-2005 06:27 PM
holychild666
09-19-2002 07:23 AM
CharlieGSanD
Performance and Tuning
22
07-24-2002 08:38 PM
Quick Reply: need help audi a8 3.0 tdi d3 2004 limp mode !!!!
