Sponsored by:
Sponsored by:
2004 Audi A8L not starting!
Old 11-28-2016, 03:22 PM
  #31
Giovanni Giovino 6.0+6.0TT's Avatar
Hello,
Just so we are on the same page, is the relay you replaced located in slot #3 located right below the orange 40AMP compressor fuse, as shown in pictures in post #52 in the attached thread link, upper relay with # 370 on it.
https://www.audiworld.com/forums/a8-...2905353/page6/
Originally Posted by astrorat
I checked the fuses and there is no fuse in space #15 and #42 was 25A and it was fine.
I went to our local VW dealer and picked up a J329 relay replacement (p/n 4HO 951 253)* and installed it. Turned the ignition key and nothing. It's still not starting.
So far I have replaced the brake switch and J329 relay and still it won't start. Dang!
*the 4HO 951 253 was an updated part number for #8DO 951 253 according to the VW parts guy
Old 11-28-2016, 03:36 PM
  #32
MP4.2+6.0's Avatar
Originally Posted by Giovanni Giovino 6.0+6.0TT
Hello,
Hi--not really in line w/ this thread exactly, but on D3 W12 I came across a relay that seemed crucial to the whole car/motor functioning. It was in the sealed black plastic box in the plenum area directly under one of the twinned ECU's that is mounted on top of the same box. Next the HVAC unit and filter. I opened it and found basically one single pretty normal Audi relay in this big space, almost like it was sealed in Fort Knox or something. In basic testing, without that relay motor seemed dead IIRC. Any sense of what that is, if 4.2 has one, if it has similar box, etc.? Since mine was working I had no reason to try to diagnose or look at wiring diagram further to try to figure out what it did.
Old 11-28-2016, 03:44 PM
  #33
Hello MP,
Me neither.... but you know I have to look now.......
Old 11-28-2016, 03:48 PM
  #34
I changed the brake switch (assuming everything was reassembled correctly) ... it still does not start. Next I will try disconnecting the battery to see if that will reset something.
Astro,
You never did tell us if the brake lights work after you replaced the BL switch, so please let us know, ALSO, any chance of posting some pictures of the dash when you insert and turn on key ?
Old 11-28-2016, 03:52 PM
  #35
MP4.2+6.0's Avatar
Hello MP,
Yep, kind of why I had to open it too... After you do, ask yourself why they didn't redo it a bit and put the ECU's inside there instead of just thrown in the plenum with a few chastity belt brackets.
Old 11-30-2016, 01:22 PM
  #36
Shark_V8's Avatar
In 30 years it's been rare to actually encounter a relay fail. I can think only a couple of times in older cars, heavy duty or high current switching.
A quick scan of the car diagnostics from the entry & start auth module will yield the issue. Other than that you have to trace voltage through the relay base terminals (in-series chain) during an attempt to starrt (=PITA)
Old 12-04-2016, 09:07 AM
  #37
Engineer
Shamoye Lewis's Avatar
sounds like he might have a neutral/park safety issue, see if the P R N D S is all lit up, if it is Neutral safety issue car will never start, if it not still try this remove the ash tray in the front of the shifter there a small hole take a screw driver and push it in the hole push it down you should be able to move the shifter out of park put it in the N position and try to start... if that doesn't work Ill tell you how the try to activate the starter manually to test it, it might just be dead also...
Old 12-08-2016, 07:38 PM
  #38
Matt94's Avatar
Default Update?
Im guessing once vcds is hooked up you'll find the starter is jammed and you may need a new one. Also I have an 04 and I don't need to press the brake to start the car.
Old 12-09-2016, 09:19 AM
  #39
Mister Bally's Avatar
Just a bit of related humor. My son's TT dash tells him to press the clutch to start, in Fatherland tongue....
Old 12-09-2016, 09:41 AM
  #40
Engineer
because the TT is manual transmission, there's no A8 in manual
Quick Reply: 2004 Audi A8L not starting!
