Sponsored by:
Sponsored by:
2006 a8 oil cooler
Old 05-17-2014, 02:45 PM
  #11
ltooz_a6_a8_q7's Avatar
I don't know why you have to remove the engine mount to get to the coolant pipe nut? You can get to the front coolant pipe nut? Can you see the whole pipe? Can you loosen the manifold enough to loosen the pipe out to remove the oil cooler bolt?
Wow, I didn't know they make it so hard to replace the coolant pipe.
Old 05-17-2014, 02:49 PM
  #12
sargemech's Avatar
the cooler bolt is directly behind the pipe. I would have to completely remove the pipe out of the way to get to the bolt. if i take the stud out of the head i might be able to clear the cooler. if not i'll have to remove manifold. not what i want to do if i can help it.
Old 05-17-2014, 03:07 PM
  #13
sargemech's Avatar
went out and looked at it again. gonna try to remove the stud and see if that gives me enough clearance to get pipe out. don't know what i'm gonna do if that doesn't work. thanks for the help.
Old 05-17-2014, 05:21 PM
  #14
mishar's Avatar
Check this tread.
Old 05-20-2014, 12:22 PM
  #15
sargemech's Avatar
well that was the trick. removed the front 2 lower exhaust studs, then the pipe moved out of the way enough to get that last bolt out. i found the bolt more of a pain than the studs. and as said the plastic piece came apart in pieces. thanks for all the help.
Old 05-20-2014, 12:39 PM
  #16
sargemech's Avatar
I'm sure the dealer doesn't sell the better one, so where can i get the metal sleeve. Is it a kit with all the o rings or do i have to buy them separately?
Old 05-20-2014, 01:25 PM
  #17
Default Nothing can't be done when you work and think hard with
problems, congratulations!!!
Please take the pictures of the 2 lower studs removed and the pipe and the hardest bolt.
Cheers,
Louis
Old 05-20-2014, 04:04 PM
  #18
greginfinity's Avatar
I think this is it:
http://www.ebay.com/itm/Aluminum-Audi-oil-cooler-pipe-for-4-2L-V8-Engine-A8-A6-RS6-Phaeton-/261324657410?pt=Motors_Car_Truck_Parts_Accessories&hash=item3cd829d302&vxp=mtr
Search: John Bufkin Aluminum pipe
gone postal
01-24-2018 12:29 PM
keithrc
11-10-2014 07:13 PM
bluenote
12v V6 Discussion
06-01-2007 05:20 PM
plugg'd
05-07-2006 10:36 PM
520
03-04-2003 08:43 AM
Quick Reply: 2006 a8 oil cooler
