Sponsored by:
Sponsored by:
MMI 2G
Old 07-24-2014, 02:25 PM
Youaliar's Avatar
Default MMI 2G
Hey A team I'm having a problem getting to my green screen. I read and watched videos that say do the same thing. Press and hold setup and hold car and wait for it to appear. When I do it I just get the adaptive suspension screen. Am I missing something. 2008 A8L
Old 07-24-2014, 03:17 PM
MP4.2+6.0's Avatar
Without memorizing button sequences, do you mean the "hidden" menu? ...
or, do you mean the basic MMI reset? I think you are probably saying the hidden menu. If so, don't you first have to check the magic box for that via VAG COM/VCDS to get it enabled in the first place?
Old 07-24-2014, 04:45 PM
Mike141's Avatar
Yep must turn it in with VCDS then do the button sequence. Without activating it in VCDS it won't work. Can't recall the button sequence, but just search hidden menu and it will tell you the sequence. I know you're new to the A8, but a VCDS cable is a must with these cars. Should be one of your first purchases after owning an Audi or VW.
Old 07-25-2014, 11:39 AM
Youaliar's Avatar
Thank you for your response. Yes I'm refering to the "hidden" menu.
Old 07-25-2014, 11:41 AM
Youaliar's Avatar
Thanks for the tip about the cable. Is it safe to grab one from ebay or is it a preferred spot to get them from? I know they're probably a lot of knock off ones,don't want to buy a faulty cable that will fail in the process of doing anyhing
Old 07-25-2014, 01:13 PM
mishar's Avatar
Buy it here and everything will work for sure. Including support.
jschick
22
01-21-2014 11:26 AM
Tapakegovagnaps
Mid Atlantic Discussion
18
08-17-2007 07:41 PM
Visti
Canadian Discussion
07-16-2007 12:07 PM
jaxjax
09-18-2003 06:49 AM
Merkin
02-17-2002 07:27 PM
Quick Reply: MMI 2G
