Couple issues on 06 A8l
My tag lights do not work.
When I bought the car, both of them were blown. The screw on the driver side was stripped so I couldn't change it. The lens on the passenger side was broken in such a way that it was hanging on but I was able to remove it to replace the bulb, and that one worked until it fell off on the highway.
I have since replace both lenses and bulbs with new equipment. Vagcom is only saying something about no/low voltage. My garage can't seem to figure anything out (they are the ones with the vagcom). I've pulled and reinstalled as many fuses as I can find related in any way shape or form to them. Any idea where or what to check?
I have an aftermarket DVD player installed in the car with LCD's in the headrests. For some reason I decided it was a good idea to reset the audio system to factory defaults at one point and now I do not have the aux input for the DVD player. I just got my garage to unlock the hidden green menu for me and I turned on the Aux inputs as the instructions I could find on youtube, but I still don't have an aux for the DVD player. Any hints or advice there?
also, what is this connector under the arm rests?
I feel like I've asked this question before, but I don't remember getting a good answer and I couldn't find my post where I asked.
That's a receiver for a phone cradle, before smartphones. I can't help you with your problems, other than to say that this should serve as a reminder to be careful with VCDS! Stay out of bootloader on the green menu!
Connector under the arm rest was for a phone cradle. Its a bit generic so it could support different types of phones. (example) Audi Gen2 Cradle rSAP Adapter - A8 Parts Forum
That said, with a ten year old vehicle, I'd consider tying into the tail light LED's and installing LED license plate lamps and be done with it. But, that's me. I usually don't Jury-Rig my A8L (2004) but this may be the fastest way to help you. It's your car, not mine.
coffeysm
01-29-2016 06:10 AM
JRomulus
A6 (C7 Platform) Discussion
01-26-2016 03:10 PM
