Sponsored by:
Sponsored by:
Headlight housing condensation after . . .
Old 02-27-2013, 10:01 AM
devilsnight's Avatar
Default Headlight housing condensation after . . .
Attempted to swap HID bulbs to 8000k. My oh my what a pain in the ***! Theres no room to access the back of these headlight assemeblies even after removing the black reservoir on drivers side. Unless you are tinkerbell, you're not getting in there.
Anyhow, so I was able to crack open the 'back door' (so to speak) of the drivers side to access the bulb and gave up after 35 minutes of knuckle grinding.
So two days later in the cold winter rain I noticed MAJOR condensation inside the housing. I went back in and noticed I didn't snap in the fender side tab.
Its 39*F and rainy here in Ohio. Is there any way I can possibly dry out this condensation before summer time?
Thanks for any advice.
Old 02-27-2013, 12:15 PM
mishar's Avatar
Access to HID's is trough wheel wells. Just take out front liner.
Don't snap back that tab and drive around with your lights on (no rain if possible). Condensation should evaporate.
Old 02-27-2013, 03:18 PM
Thanks mishar, do I need to fully remove the liner or can I get away with pulling it down?
Old 02-27-2013, 04:39 PM
Lexdiamondz10304's Avatar
Fully remove it, unless you want to continue to struggle. I was able to swap my bulbs in about 30 mins (both sides) from start to finish.
Old 02-27-2013, 04:41 PM
Whoa that's fast, did you have the car on a lift with the wheels off? It's seems some if the screws are deep in towards the center if the car.
Old 02-27-2013, 04:59 PM
I removed the wheels. Just a standard Jack. Theres a few screws, plastic rivets and plastic speed screws.
Old 02-27-2013, 05:01 PM
Very helpful! Thanks a bunch Lex!
Old 02-27-2013, 05:06 PM
Also, note the orientation of the D2s bulb and the clip that holds it in.
Old 02-28-2013, 07:21 PM
This WORKED!!!
Old 03-01-2013, 04:19 AM
[IMG]<a href="http://s1029.beta.photobucket.com/user/devilsnight74/media/58FF8B53-1DD1-4094-9891-497ED996653E-4916-000002ADA5E9C5AF_zps07f09221.jpg.html" target="_blank"><img src="http://i1029.photobucket.com/albums/y357/devilsnight74/58FF8B53-1DD1-4094-9891-497ED996653E-4916-000002ADA5E9C5AF_zps07f09221.jpg" border="0" alt=" photo 58FF8B53-1DD1-4094-9891-497ED996653E-4916-000002ADA5E9C5AF_zps07f09221.jpg"/></a>[/IMG]
This WORKED!!!
wolywood
A4 (B8 Platform) Discussion
06-26-2019 04:32 AM
burtonsnow13
01-12-2011 02:24 PM
collegedude10
03-06-2008 01:58 AM
SHUDS4
01-09-2003 07:11 PM
konyo
12-21-2001 07:52 AM
Quick Reply: Headlight housing condensation after . . .
