Hood release wire snapped, hood closed
#51
Went in through the fender. Tried the long screwdriver to the latch. Thank you but I'm not taking a Sawsall to the car. If that's how the dealer does it, fine. I will get to hold the dealer responsible for any damage. I spoke with Audi corporate and they had a real hard time defending this design as being anything other than bad engineering. A case has been opened and I got the sense is I am NOT the first A8 owner to complain of this problem. I'd like to know how many other Audi's use this idiotic design! In any case I'll advise how the dealer gets the hood open.
#52
I should note, I have carefully considered the reciprocating saw method. It's not that I'm opposed to it but time constraints are setting in. I need this done. Keeping in mind this is a 2009 there is so little space available to get a screwdriver in there let alone a Sawsall. I've got an idea and will share it just as soon as I the hood open.
#53
I looked at the latches tonight, I don't even know how
anyone can get into anything if both of the hooks are locked. I looked at every which way, they really caged the latch well, no way to get in. I looked under the grill, I could put a coat hanger through only to the top of the radiator, the whole cables are TUBED all the way to the latches.
I need to make an emergency latch cable this weekend. The latch cable are so dinky thin. These macho mucho over powered yank will break it for sure.
Cheers,
Louis
Cheers,
Louis
#54
As far as the "idiotic design" goes; it is meant to deter theft & vandalism. Seems like a pretty good design if you ask me. I know many people that suffered from. stolen batteries in the pre inside hood latch days.
I know, the A8's battery is in the trunk/boot but you get the idea.
#56
#57
I will just write down how I got it fixed, I didn´t take any pictures unfortunately but I will try a simple instruction in case someone else got this fault – I am from Sweden so you must excuse if I use some strange words...
1, I Removed the wheel and the plastic that covered the xenon headlight etc.
2, I tried to reach the small black plastic box just above the xenon headlight, it was barely possible.
3, I was able to pull the whole box with pliers, and the hood opened.
4, I didn’t replace the complete wire, I was able to repair the broken one but I guess that a new wire is the best solution!
#3--pull the whole box
do you mean you grabbed the box with the pliarrs and pull the box
and did not pull a cable ?
#58
Another message to all those that have pulled the wheel liner, found the cables, pulled on them but the hood still wont pop. In this scenario, the cables have popped out at the actual lock. As long as one side of the hood is able to pop, you'll want to wedge the hood open and cut the hook on the hood on the side that isn't opening. You can do it with a long reciprocating saw blade. you'll have to be cautious in order to try not to damage more than you have to but the end result will be that you are able to open the hood 15 minutes later. You'll need to buy a new hood hook, plastic cover for the hook and new cables..... Problem solved for minimal money spent and the least amount of damge....
first thing I thought was.
is there a secondary latch ? No.
is it electronic in nature to use vcds ? No.
then I thought cut the hook !
I'm not doing the wheel liner thing
#60
I just had same issue, cable to driver side latch broke. Took wheel well inner cover out, played with cable and waisted lots of time. Used wood shimm to hold hood up and made bent screw driver to try and hit release point. (see other thread here about it) 3 hours no luck. Got 10 " metal cutting blade and sawall, cut it in 3 minutes. Use duct tape to protect grill and hood edge. Don't waste time just cut it. I found cable was broken 1/2 " from end.
I used krimper and stainless steel picture hanging wire to fix the cable. I also found a hole in release latch and attached a string to it, so I can release it if it happens again.
Haven't got the new piece yet but hood holds down just fine with one latch. Anyone know if this steel box latch is a common piece on all audi's?
