key stuck in the ignition switch
Hey guys. I have a serious issue here, my key is stuck in the ignition switch and i have no access to the truck (only have one key) because the key is stuck and the car battery is dead. the only access to the truck is the small panel that opens up for the ski bag. sad to say that i had to cut away the ski bag to see into the trunk but i just cant reach the battery connectors. is there away to remove the key from the ignition? or is there anyway that i can boost the car w/o the plugging up to the actual battery?
Since you already cut the ski sack away, can't you operate the "kid is stuck in the trunk" lever on the road side interior of the trunk lid? It is glow in the dark. A looooong broom handle or remote paint roller extension or some kind of gardening tool you might have can be used.
Just a thought.
Just a thought.
Just a thought.
Just a thought.
Or, [sarcasm on] go the s4master1 route and replace the assembly. You can have your A8L flatbedded to his shop in Culver City, CA (fee applies) like a couple of his customers do or just take it to a shop. His shop sees about 20 A8's a month so he's gotta be doing something right [sarcasm off].
Thanks everyone for your help, my local dealer isnt very friendly with advice. But wish i would have read the book b4 killing the ski bag although bc i cut it so clean n close i think it could be reattached. That little button worked used a toothpick and it worked like a charm.
key stuck issue
I had the same problem. Mine is an 05 model, but that year does not have the little hole to remove the key manually. Since you cut out the ski pack just use the child locked in trunk lever and open it that way. Good luck!!
05whtaudia6
04-21-2009 01:11 PM
