Lighting / Grounding / Brake Alarm Issue
I have a issue with a 2003 A8 that is kind of different.
The symtoms are:
When the headlights are off:
Light warning/ warning chime when I push the brake pedal.
Goes away after brakes are released. I did notice that the front running lights glow brigter when I push the pedal.
When the Headlights are on:
Unhappy Triad Condition - BRAKE LIGHT / EBS / ABS
Goes away after you restart the vehicle with the headlights out.
I think also that the Brake lights are dimmer than normal.
The Ross diagnostic tool reads a Brake Light Switch code, but drilling down deeper, I can see both poles of the switch "pulling in" when I press the pedal
This sounds like a bad ground to me. Does that make sense?
Has anyone seen this one?
Does anyone know Where physically the lighting system grounded in this car?
Can this be caused by bad lamp connection(s) ?
Thanks for your help!!!
Joe
The symtoms are:
Joe
Sounds like a massive ground fault as well. The harness on these cars are pretty good (assuming you have a D3, not a D2 since you say 2003. Model Year 2004 was first year for D3 in the US.
An official service manual is mandatory for these cars IMO. I believe grounds meet near the headlight assemblies.
That said, the brake light switches fail often on these cars.
