Sponsored by:
Sponsored by:
Parking Brake Failure?
Old 04-21-2014, 10:37 AM
pmdeaver's Avatar
Default Parking Brake Failure?
Just had this appear, and it stays illuminated while the engine is on. Is this something associated with the rear brakes simply needing service or something else?
Old 04-21-2014, 11:28 AM
mishar's Avatar
As usually, VCDS scan would shed more lights on the problem.
Old 04-21-2014, 02:08 PM
snatchman's Avatar
Without an VCDS scan I can not be positively sure of what your problem is. When my D3 had that issue, I done a rear brake job and it cleared the light. My pads was extremely low, but I never got the low pad warning. Why this gave me a parking brake malfunction, I could not tell you, but I would check for low pads first.
Old 04-21-2014, 02:47 PM
pmdeaver's Avatar
Thanks, Snatchman. I had come across some old posts, and that's what led me to that conclusion. Still haven't purchased Rosstech yet. Really need to do that.
I appreciate both your comments!
Old 04-21-2014, 08:38 PM
MP4.2+6.0's Avatar
Default I've gotten the rear parking brake light...
with low pads, but also got it when it wasn't holding the correct pad thickness setting (related to a prior pad job). Then you need VAG COM to reset it, like you do to open them to do the pads. All paths lead to a VAG COM here...
Old 04-22-2014, 04:45 AM
pmdeaver's Avatar
Thanks, MP. Appreciate the additional insight!
Old 04-23-2014, 07:00 AM
boz151's Avatar
I've also gotten it with a faulty parking brake switch and separately with a faulty parking brake module, both of which I had replaced and it cleared up each time.
Chad09W12
08-21-2018 06:36 AM
mattc12
06-12-2017 03:46 AM
sharkaTT
NY / NJ / CT Discussion
12-15-2008 04:37 PM
technics100
03-16-2005 12:14 PM
KingBC
01-06-2005 08:09 AM
Quick Reply: Parking Brake Failure?
