Sponsored by:
Sponsored by:
Parking brake error - 02439 - solution found (not new)
Old 04-08-2015, 09:17 AM
carl viking's Avatar
Default Parking brake error - 02439 - solution found (not new)
I have had a persistent error for my hall sensor, see scan below from today:
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000632
Shop #: WSC 25161 444 70047
VCID: 204FF3D6F36C63214FB-8075
3 Faults Found:
02439 - Right Parking Brake Motor Hall Sensor
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11110100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 233
Mileage: 138360 km
Time Indication: 0
Date: 2014.12.13
Time: 15:35:12
Freeze Frame:
Voltage: 12.01 V
Count: 95
02596 - Rear Brake Pads Worn
008 - Implausible Signal
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 2
Reset counter: 233
Mileage: 138344 km
Time Indication: 0
Date: 2014.12.13
Time: 14:36:57
Freeze Frame:
Voltage: 13.66 V
Count: 61
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 4
Fault Frequency: 3
Reset counter: 18
Mileage: 138344 km
Time Indication: 0
Date: 2014.12.13
Time: 14:36:57
Freeze Frame:
Voltage: 13.66 V
Count: 97
Yes, I know the date says December last year, but I was unable to reset these errors. And the light was on. Over the last few months, I have done teh same routine: separating the connector, putting some contact solution on it, the light went away and the top error (02439 / 004) went away (the other two remained, 02596 and 02439 / 008).
After a few days, the light always came back on and the error re-appeared.
Monday I swapped to summers, took apart the connector again and also took the time to physically press the connectors together, using a thin set of pliers. Drove the car and the light was off, but amazingly, today (after about 40 miles of driving and 4 or 5 ignition cycles) I was able to clear the error codes!
So - for others who see the same problem, seems like the Hall sensor connector is very sensitive to less than perfect connection in the connector, and that a certain number of miles, time, or ignition cycles resets the error to a state where they can be erased.
Old 09-09-2017, 04:24 AM
EHLO's Avatar
How did you take the connector apart?
I was able to remove the purple piece that holds the orange seal in, which does me no good, and that's about it.
Did you remove the round plugs around the wires on the back somehow, to get to the back part of the female connectors?
Thanks.
Old 09-09-2017, 05:03 AM
Hmmm, it is a while back (error never came back by the way). it I recall correctly, I just used a very thin set of needle nose pliers and squeezed.
Old 09-09-2017, 05:15 AM
EHLO's Avatar
Thanks Carl.
So not actually disassembling the female connector attached to the EPB motor, but just going in from the side of the connector that plugs into the male wiring harness, and pressing the visible upper and lower ends of each of the four terminals together?
There's not much room there, that must be a very thin set of pliers!
tjf
9
01-15-2019 07:45 AM
TrevorAustin
01-12-2019 05:20 AM
wfroehlich
07-06-2012 12:29 PM
JoelA-K
Audi 100 / A6 (C4 Platform)
04-18-2002 07:54 PM
Quick Reply: Parking brake error - 02439 - solution found (not new)
