S8 Engine sometimes starts sometimes don't
#21
Cleaning audi s8 carbon buildup
Hi,
I have cleaned the build up based on this video on the audi s8 :
https://youtu.be/Ugh9vPz2Zd8
Reading injector signals with an ossilloscope from audi s8 v10
Cleaned and retested injectors
Pressure washed air intake manifold audi s8 v10
You are welcome, I would appreciate it if you could document the process of carbon cleaning, my S8 has never had it done so any pictures you could provide and tips would be great
BTW if you are using VCDS for measuring blocks, there is no label files for the S8, this stops you using adv measuring values. but I contacted ross tech and they advised that copying and renaming the
07L-910-552-BUJ1.clb
07L-910-552-BUJ2.clb
07L-910-552-BUJ3.clb
to
07L-910-552-BSM1.CLB
07L-910-552-BSM2.CLB
07L-910-552-BSM3.CLB
doing this will give you the ability to get adv meaus values from the engine controller
to
#22
Audi s8 v10 injector opening time signal neasuring
As I posted before it looks like the audi s8 v10 sometimes starts and sometimes not caused by a voltage drop at the injectors. Around 28 to 35 voltage.
The injector opening time was measured with an oscilloscope during cranking (engine start)
Any advice would be appreciated, where to look for bad ground connection or which relay that supplies the ecus.
Thank you,
Gabor
Low (faulty) voltage reading: 32 V at injector opening time signal
Correct voltage and injector opening time on audi s8 v10 (63.2V)
Thank you,
Gabor
#24
On relay location:
Assuming it is the same as the W12 with the twin ECU's, you see both of them in the plenum area once you remove the trim covers. You will notice one is screwed down on top of a black plastic box--I think it is the one closer to the (USA/continental Europe) drivers side. Inside that box is the relay that powers the ECU's and most everything else around the engine electronics--very little else is inside that plastic box. IIRC you have to take out the other ECU (toward the passenger fender) to get the one out on top of the plastic box. You will run into a few security/antitamper small bolts/screws, but they can be removed with some normal tool work. If you want it to look "factory" afterward, some of the front brake shield bolts from newer models with Torx heads (like RS5) fit very well. BTDT.
The relay itself is a very simple one and not very expensive. To be clear, what that relay is not is some very complex pre-ECU era relay with lots of different contacts. It basically just takes a signal and then turns power to everything on, including the ability to keep power supplied to some of the after run circuits like water circulation if needed.
Thank you,
Gabor
Thank you,
Gabor
#25
Hi,
Here is what the solution was:
Under the air intake manifold the injector anchor bolt were audi but 1 mm bigger than what it suppose to be, therefore the air intake manifold could not sit on its bed correctly and the car got false air all the time, which made the computer send less gasoline to the engine, not enough to start the car.
We ordered smaller bolts and the car starts perfect now!
Thanks everybody
Thanks everybody
#27
They were original audi bolts, but they just were not the right bolts, not the ones that were suppose to be there. I assuming that someone did not put the right bolts back after working on it, but Im not sure what happened since I bought the car like this from Germany.
#28
Good find, I bet your glad. A smoke test should have highlighted that for you sooner but you were in there and done a carbon clean too, so a win win either way.
ECS Tuning-Audi
A4 (B8 Platform) Discussion
21
09-11-2021 04:04 PM
ECS Tuning-Audi
09-01-2015 08:27 AM
