Sponsored by:
Sponsored by:
2014 LED headlights vs. 2005 halogens
Old 01-13-2014, 08:17 PM
FallenBMWer's Avatar
Default 2014 LED headlights vs. 2005 halogens
Will I experience markedly better nighttime illumination in a 2014 A7 or A8 with full LEDs than in my current 2005 A8?
Old 01-13-2014, 08:21 PM
2k6blacka8's Avatar
Yes the newer LED's are significantly brighter than the stock 05-10 LED bulbs. I did see people change to a brighter LED bulb on an 05-10 but still not as bright as the current ones. Some states won't recommend using those lights as primary night illumination.
Old 01-13-2014, 09:12 PM
jakematic's Avatar
Absolutely - night and day difference, pun intended.
The LED illumination is very pure white light, intended to mimic the sun, and has an incredible range.
Width of the beams is incredible too, making it far easier to read road signs.
Even the DRL's are so bright in full daylight that the vehicle gets noticed a lot which I consider a good safety feature.
Following my brother home from picking up a new car for his wife I 'accidentally' hit the high beam and he said it nearly blinded him at over a mile ahead of me.
Personally I'd never go back to non-LED and am looking forward to the matrix LED when it is approved, and the laser concept lamps in the future.
EDIT: Should have mention my last Audi was a 2005 A8L with BiXenon
Old 01-14-2014, 04:44 AM
1Wasserwerks's Avatar
The demonstration of the matrix lighting is awesome! I've seen the video before, then found out that they were not approved in the U.S.
Booo!
Old 01-14-2014, 06:37 AM
mishar's Avatar
+1 Booo! But only if it really works like in that ANIMATION.
Old 01-14-2014, 07:04 AM
jakematic's Avatar
It really works.
Trust me, there are a lot of us waiting with bated breath for the approval.
We still aren't certain if the 2015 will get matrix or not.
The ridiculous part is it not approved because there is no High/Low beam switch according to the gooberment.... sigh.
Old 01-14-2014, 08:38 AM
I think there were also light size requirements and the fact that the whole light assembly had oscillating patterns which are not allowed either.
Old 01-14-2014, 09:52 AM
mishar's Avatar
Originally Posted by jakematic
It really works.
Trust me, ...
To thrust you I must know that you tried it personally. I already thrust you that you thrust Audi.
Old 01-14-2014, 01:10 PM
TSHong's Avatar
I've been behind a couple with LEDs and they do have a wide light pattern. The only thing I want to know is with HIDs, most people prefer 4300K temp for best lighting but LED's are 5700K and closest temp to daylight. I've always liked 5000K temp because 4300K seemed a little to yellow for me.
ECS Tuning-Audi
04-26-2017 06:13 AM
IlyaV
09-19-2015 01:13 PM
HankJ
09-10-2015 10:53 AM
scopeman07
A7
09-09-2015 03:27 AM
Beena
A4 (B8 Platform) Discussion
09-02-2015 12:01 AM
Quick Reply: 2014 LED headlights vs. 2005 halogens
