VCDS Ride Height Adjustment
#101
Have you done this:
[Select]
[34 - Level Control]
[Coding - 10]
Stock code is: 0015510 Ride height can be adjusted by changing those 5's. The first one is for the front and the second one for the rear. 4 - 0 will set lower ride for 5 - 25 mm (5 mm per digit). 6 - 9 will set higher ride for 5 - 20 mm. This will change all MMI settings for the same amount. Make your choice than:
[Do It]
Heights are probably different for S6 but the main idea is same. Unless it is totally different system. In that case I can't help you.
[Select]
[Coding - 10]
[Do It]
#102
Will check on it tomorrow, as it is 330am here! Thank you so much for the info, more than anyone else has been able to offer! My dealer even refused to lower it, though I've heard others have done it for customers. Anywho thanks again!
#103
S8 Stock code
Does anyone know what the stock code is for an S8?
I presume it isn't 0015510, perhaps 0011110 (20mm lower than standard A8).
I feel like mine rides a bit high and wonky so will be recalibrating this weekend if the weather holds out.
Thanks.
Thanks.
#105
Well.... tried this today. Could not get it to work. I went through the first few steps. Got the new values close to where my measurements were but couldn't get to channel 5. It shows an error. Not sure where to go from here. now I am stuck in automatic mode and have a fault code that says the suspension positions are not learned.
Any thoughts?
Phil
Any thoughts?
Phil
#106
Read the instructions (first post) again and be sure that you understand everything. If there is any doubt ask before you do it again. Or come to Vancouver and I will do it for you.
#108
Mishar, thank you for this write up. Just did this 10 minutes ago. It took me about 45 minutes total once I started the procedure.
To those looking to do this, read this thread 3 times before you start, all the answers are here.
I went with "01" coding and achieved the results as shown below.
#110
My D3 has the sport suspension so it's at 396/378 to start. I was able to get 381/363 to take the other night but I had to try to tweak it a little more...
