Knock in the engine. 2.5tdi 85kw.
Paul..we did not get that engine over here in the USA..so not many here generally can offer a valuable opinion. I would get someone to check the timing belt and tensioners..as a guess.
Do post what the solution happens to be?
So I've been searching whole youtube for someone that has or had the same problem and I found a few videos that shows similiar sounding cars. Apparently it could be fuel pump, vacuum pump (i don't think thats my car problem) so the one reason left is jumped timing. Timing belt jumped 1-2 tooths and now my piston is touching valves. And also valves might be already bent by now, but I'll check on this theory and let you know.
brupm
08-27-2012 11:30 AM
pinoykool
10-08-2006 10:26 PM
TXAH606
10-20-2005 05:44 PM
