reverse light and brakes like
Old 02-16-2017, 10:15 AM
eyan's Avatar
Default reverse light and brakes like
reverse light and breaks light not working on right side only.
on the left side is works as normal
Old 02-16-2017, 06:47 PM
Rogviler's Avatar
Ah yes, this is a specific problem that I had. As soon as I remember what the solution is I'll post it.
-Rog
Old 02-21-2017, 07:43 AM
audi-driver1126's Avatar
check fuses? these cars have seperate fuse banks for left and right lights i believe
Old 03-11-2017, 07:06 AM
TEF1701's Avatar
Check the connector at the tail light cluster for corrosion. Also follow each of the brass pathways from the harness to each bulb and check for corrosion. I noticed my lights weren't working either, and I found a ton of green corrosion on the contacts. It was bad enough that my cluster was getting hot from the resistance. Use emery cloth or fine grit sandpaper to clean each contact until it's shiny. Then put dielectric grease on the terminals to prevent future corrosion.
Joeltron
12-12-2013 06:47 PM
theMaab
05-11-2010 11:05 PM
SpeedCrazie
02-24-2010 12:51 AM
Sler
07-07-2008 05:54 PM
King13
01-29-2006 03:00 PM
Quick Reply: reverse light and brakes like
