5th gear boost surge 12psi-15psi
Old 04-28-2012, 01:24 PM
5000turbo's Avatar
Default 5th gear boost surge 12psi-15psi
it holds at 18 1-3 15psi in 4th and then flexs between 12psi and 15psi in 5th, i'm not quite sure what it is... I don't think its a boost leak so idk? any ideas?
Old 05-06-2012, 05:17 AM
88A5TQ's Avatar
Hey. I don't know squat about boost controllers but maybe you can set different values for different gears but I doubt it. I would start by checking all vacuum lines to and from the controller and wastegate and the wastegate diaphragm. Also maybe give greddy customer service a call. Another consideration might be that the Ecu is limiting boost somehow through the controller (idk?) because of a rise in intake/coolant temps. Does it behave like this even with the water/meth setup replenished?
Last recommendation: join motorgeek and repost these questions. EFI is the life-force for the majority of vehicles over there.
Old 05-07-2012, 11:37 AM
AudiQ5sleeper's Avatar
Vacuum leak most likely. but use a fog machine to find that leak.
Old 05-12-2012, 08:12 AM
5000turbo's Avatar
There is a hose that connects from the intercooler piping to the turbo inlet that is kinked.... possible issue/>
johnkk
06-28-2017 04:33 PM
Nasti00S4
11-12-2005 07:46 AM
reefer_bob
01-22-2003 10:15 AM
Digit@lex
10-25-2002 11:46 AM
Quick Reply: 5th gear boost surge 12psi-15psi
