20v Not getting spark on all cylinders
Old 10-26-2014, 04:56 PM
Finni91's Avatar
Default 20v Not getting spark on all cylinders
I have a 91 audi 90 20v 7a and one day she wouldn't start. I checked to see if I was getting spark and was not on #2 and #4. I checked to make sure the hall sensor was getting the correct power and it was. I tried a different distributor and still no changed. I swapped the ecu from my parts car and now I get spark on #4 but still nothing on #2. So Im assuming my ecu is shot? Whats my next step? Is there anything I can check before I try to find a new ecu?
Old 10-27-2014, 10:04 AM
yodasfro's Avatar
I think you need a new cap and some plug wires. Do you have the wires in the correct order on the cap?
Old 10-27-2014, 10:13 AM
Finni91's Avatar
I've tried multiple caps. Wires are in the correct spot.
Old 11-01-2014, 03:54 PM
IdahoDoug's Avatar
I don't know the numbers but you can check the resistance of the wires. Or switch wires around and see if the fault follows the wires. If its getting colder where you are, older wires with faults will get "faultier"
Doug
Old 12-17-2014, 06:32 AM
Finni91's Avatar
Doug
Ive swapped wires and test straight from the cap. No change. Its cold here now and nothing has changed.
Old 12-18-2014, 01:51 PM
Hybrid_Hatch's Avatar
have you tested spark outside of the chambers? IE have you pulled the plugs and tried to have it spark against something in the engine bay?
Old 12-21-2014, 05:49 AM
Finni91's Avatar
Yes multiple times. There is absolutely no spark coming from #2 and #4. Like I said, I've tested straight from the cap.
Old 12-22-2014, 05:38 AM
x19
x19's Avatar
How about, you have a open electric wiring or power at the injector?
You have to check the voltage or power at the back of ECM that you need to do I think. Good luck and Happy Holidays. x19
Ps, What is your ECM # ? I may have.
bd__14
09-23-2012 03:42 AM
Snow Trooper *Swiss*
9
09-25-2006 09:17 PM
90mtl
09-16-2006 03:50 PM
jurq
05-04-2006 05:44 AM
Sheilige
12-24-2003 10:06 AM
Quick Reply: 20v Not getting spark on all cylinders
