Buying a allroad but!
Old 08-05-2014, 06:56 PM
torturebori's Avatar
Default Buying a allroad but!
The front passenger airbag is not holding air.
Sure when you let it fill up it will, but the compressor is constantly going and the button on the dash is constantly blinking.
Am I to assume this is not a good airbag?
Also this is a 2002 2.7L and they are asking 7450.00 for it
It is very very clean in and out, has third row seat(if you can call it that)
Everything else seemed good on it.
thoughts?
please help
Old 08-05-2014, 08:21 PM
Banned
PaperToast's Avatar
with the leaking bag, id go no higher than 7k.
other than that, if all the records look good, go for it
Old 08-06-2014, 02:38 AM
Thanks...I know it's an adventure but this car has me wraped
Old 08-06-2014, 04:44 AM
snagitseven's Avatar
How many miles? Has the timing belt/water pump/thermostat/tensioners been done? Even if low miles, it should be done after 10 years at the least. Have you had it checked out by an Audi mechanic? Any repaired damage? Hard to know if it's a good value w/o further info.
As to the air springs, figure a pair will need replacement. If going with Arnott's, plan on about $800-900 installed. (OEM would be over twice that). If the compressor keeps running, it too could burn out and could need to be replaced.
Old 08-06-2014, 05:07 AM
thejulex's Avatar
Sounds like a lot for 2002 to me. I bought 2001, 6 speed, 5 years ago for 6250 without any issues and in excellent running condition... It wasn't a steal either, I had three to choose from at the time in the same price range, 2001 - 2002, similar mileage (120-140k) but with full service done on each (so relatively to almost new timing belt, one had jsut brakes done and new front OEM bags and other stuff). I eventually went with 01 with new TB, new front bags and some other misc stuff. In very good cosmetic condition.
Old 08-06-2014, 12:54 PM
"How many miles? Has the timing belt/water pump/thermostat/tensioners been done? Even if low miles, it should be done after 10 years at the least. Have you had it checked out by an Audi mechanic? Any repaired damage? Hard to know if it's a good value w/o further info.
As to the air springs, figure a pair will need replacement. If going with Arnott's, plan on about $800-900 installed. (OEM would be over twice that). If the compressor keeps running, it too could burn out and could need to be replaced."
Miles 90,457,
Carfax shows - Timing belt, Water Pump, Thermostat and tensioner done at 74k at Audi dealership
I looked at the Arnotts replacement kit including the air compressor and it's $1339.99 not too bad would be my guess.
If I can get a year from the ones that it has now.
Over all it drove great, a lot better then the previous 5 I test drove, body was way better as well, no rust at all for a midwest car, just that air bag going down and breaks shaking a bit.(they say they will fix both issues)
We will see what happens, ill keep you posted
Old 08-06-2014, 01:16 PM
Kneale Brownson's Avatar
The longer you drive with a leaking airbag(s), the more wear and tear on the compressor. Stress the compressor too much, and you are likely to blow the suspension control module, another pricey item.
Old 08-07-2014, 01:18 PM
Thats why I am hesitant at the moment...Have a different one to look at tomorrow so I hope she's the one
Old 08-11-2014, 04:37 AM
OK guys just wanted to let you know that I did buy my 1st allroad.
Went with a
2004 65K Black exterior 2 tone grey inside
very clean in and out.
only thing missing is the **** to adjust the side view mirrors
She's a beauty.
I am going to clean her up to my standards and post some pics later.
aesj80
Audi allroad
01-22-2015 06:28 PM
bugbehr
05-27-2012 04:10 AM
Thomas Carey
05-10-2012 10:19 AM
MRSK
13
06-29-2007 04:17 PM
s ate
07-02-2004 06:24 PM
Quick Reply: Buying a allroad but!
