Brakes Discussion Discussion forum regarding brake tuning, upgrades and questions
ABS module changing does it need programming
Old 11-07-2014, 12:50 PM
elhajj's Avatar
Default ABS module changing does it need programming
Hi guys
I just joined the group hope you can help me
i bought an audi a8 2004 had some mechanical problems all fixed still one which is major The ABS module as it is scanned it shows that the whole module needed to be changed (abs, esp brake lights are on in the dash )
I know that i have to change it and i will
but my question is if i got the abs module with the same part number exactly does it need online programming or only reseting the whole system by vagcom
because if it needs online programming i will do it in a garage and they charge around $300 only for programming and if it doesn't need online programming i will change it by my self
Best thanx
Old 11-08-2014, 05:04 PM
mishar's Avatar
Welcome!
VCDS programming is all you need. No need for dealer online programming.
It is better to ask model specific questions in model forums. A8 D3 forum has all you need about ABS programming.
Old 11-09-2014, 07:19 AM
elhajj's Avatar
Originally Posted by mishar
Welcome!
Thank you very much
but what happened i couldnt find the exact same part number the 3 last digits are different so do i need online programming now or no ??
Old 11-09-2014, 09:36 PM
mishar's Avatar
Where are you looking? Here you can buy it and it is not so expensive. Part number is 4E0910801D
Old 11-23-2014, 11:46 PM
elhajj's Avatar
Default bought new one and replaced
Hi mishar
i just bought a new one with part number 4E0 614 517E
And the one that was fitted on the car was 4E0 614 517A
Please i really want to know does it need online programming or only reset with a vacom connection any help will be really appreciated because this car is getting me nothing except headache
elhajj
11-23-2014 11:48 PM
apj
07-26-2012 12:38 PM
MRog985
07-27-2006 06:03 PM
silveravnt
02-19-2006 08:08 AM
stanj
07-11-2005 01:16 PM
Quick Reply: ABS module changing does it need programming
