Cheap Sim Card and Plan for Audi Connect
#211
I just got a freedom pop sim which gives you enough data for a month for free. Other people recommended it but I can't get it working. Just wont connect to data even though my 3g sign is showing on the display panel.
#212
After you receive the sim, go on the website and register it to your account. After an hour or so to give them time to process the info, insert the sim then go to tel, connection settings and enter the following:
APN: pwg
User: enter a single space
PW: leave blank
Test with one of the Audi Connect services, i.e. weather, online destination or Google Earth.
APN: pwg
PW: leave blank
#214
That APN is for US Mobile, not Freedompop. You have to change the APN as directed from their website.
#215
I'm having trouble getting freedompop SIM to work. I changed the APN to freedompop.foggmobile.com, username is one space, nothing in the password field and roaming checked. When I go to online status overview, it shows AT&T data service with "good" strength. At the bottom of the screen it displays AT&T in the center and to the right shows 3G and 4/5 bars lit up.
When I try to do a Google location search, it asks to make a data connection, I say yes, and it fails after a few seconds.
Any idea what could be wrong? 2014 Q5.
#217
You don't change the user name or password. Change the APN and select data roaming. The card that comes with the SIM card tells you exactly how to set it up. I have one in both Q5's and they both work. I've never come close to using all of the free data.
#218
do you have the data only sim or th data/voice/text cheap one? I have the latter and can't get it to connect. APN is freedompop.foggmobile.com and roaming is checked - no luck.
#219
I have the data, voice, and text sim cards. I have one in both Q5's and in my iPad. Remove the card and reinstall it. If it won't work contact their tech support.
#220
strange. I have taken it out a couple times and let it rediscover the network, which works, but online location search just fails every time. There is one space in the username field, but I can't delete that as it won't let me press OK if I do. I'll try contacting support.
