Newbie needs help please !!
Old 01-03-2014, 07:46 PM
ryanaudi's Avatar
Default Newbie needs help please !!
Hi all I just purchased a 2010 Q5 3.2. When I do from drive into reverse I feel a "rattle / shake" in the steering. I was purchased private party so no Audi Care any recommendations / advice? Thank you !
Ryan
Old 01-03-2014, 08:03 PM
NABS4's Avatar
Ryan
Are you still under the 4 yr/50 k mi warranty?
Old 01-03-2014, 08:07 PM
ryanaudi's Avatar
No I bought the car from a private party so that warranty is not transferable I was told. Also it has over 50k ..
Old 01-03-2014, 08:17 PM
ryanaudi's Avatar
This actually seems to be a pretty common issue..
http://www.audiforum.ca/q5-q7-58/aud...ibrates-68590/
Old 01-03-2014, 08:47 PM
NABS4's Avatar
New vehicle warranties are always transferable. BTW, Audi Care is not a warranty package, it is a scheduled maintenance program, which is also transferable.
Old 01-04-2014, 05:57 PM
ryanaudi's Avatar
it has about 90k on it so im not sure if that still falls under the warranty for not?
thanks again for your help!
Old 01-04-2014, 07:33 PM
snagitseven's Avatar
Unfortunately, it's way out of the 50K miles original manf. warranty.
Old 01-06-2014, 06:04 AM
JGA5Cab's Avatar
Are you talking about when sitting still or when moving slowly and steering? There is a hose replacement for the steering if the wheel seems to shudder when you turn it at slow speed. It was done to my 2010 Cabriolet. I am not sure if it applies to the Q5 V6.
My Q5 sometimes has a tingle in the steering at idle with the car in gear. It comes and goes.
Old 01-06-2014, 02:21 PM
ryanaudi's Avatar
mostly at very slow speeds backing up... like 2 mph.. also is there a way to get the mileage off the DTC I want to show something else there like hours or something.
Old 01-10-2014, 05:36 AM
JGA5Cab's Avatar
That sounds like the problem that I had with my 2010 Cabriolet. They changed a hose and it got better. It doesn't completely go away after the fix.
You have two ways of changing the display in the center. There is a button on the underside of the wiper stalk. Have you found the rocker switch on the end of the wiper stalk? Both of those change what's in the middle.
Chigger
S4 (B8 Platform) Discussion
02-10-2016 11:33 AM
markvh
Q3 Discussion
08-28-2015 08:08 AM
cubsfan
04-23-2001 04:19 AM
TommyO
12-05-2000 06:55 AM
WECoyote-SuperGenius
11-27-2000 06:38 AM
Quick Reply: Newbie needs help please !!
