no heat on driver's side
Hi everybody.
The patient is a 3.6L 2008 Q7 dual zone clime.
Now that the temperatures are dropping, my wife noticed that her side (driver) of the car is not getting warm. Passenger vents are blowing hot air while driver's not.
After a quick scan, it seems that I need to replace the "Actuating Motor for Temperature Flap"...
01809 - Actuating Motor for Temperature Flap; Left (V158)
003 - Mechanical Failure
I had a similar problem with an older Explorer and I was able to replace the part easily.
However, the Q7 seems more complex than that Explorer and I would not want to dismantle things that I don't have to.
So what I know (or think I know) is that this actuator is accessible by removing the plastic panels under the steering wheel and trying to get under the center console.
I am wondering if anybody here has some experience in this area and can tell me the shortcut to get to this actuator.
Extremely helpful will be a diagram showing the hvac parts... if anybody has one that he can share.
And on a different note...
The VCDS scan shows under each fault code, among other things, the mileage, time and date. I am curious if these are pointing to the moment when the fault happened, or they are somehow related with the PC's time and date.
Besides the HVAC fault code, my wife's Q7 has some other codes that I would not rush to fix, like:
Address 5C: Lane Maintain. Labels: None
Part No SW: 4E0 910 217 C HW: 4E0 907 217 C
Component: J759 LDW H06 0070
Revision: 00H06012 Serial number: 400207B0200061
Coding: 0000101
Shop #: WSC 31414 790 00001
VCID: 204FC957F384921EBBD-8075
3 Faults Found:
16364 - Control Module - Programming Error; CPU 2
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 44
Reset counter: 255
Time Indication: 0
16363 - Control Module - Self-Test Error; CPU 2
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 47
Reset counter: 255
Mileage: 58224 km
Time Indication: 0
Date: 2014.07.03
Time: 10:44:33
02858 - Windshield Heater for Directional Stabilization Assistance (Z67)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 4
Fault Frequency: 255
Reset counter: 28
Mileage: 65535 km
Time Indication: 0
Date: 2014.07.18
Time: 07:48:61
But the thing here is that back in July the car was still under the 60 days warranty, and I was wondering if the dealer would consider that the fault happened under the warranty (and agree to fix it).
Any thoughts?
Thanks a lot for any input!
Coding: 0000101
3 Faults Found:
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 44
Reset counter: 255
Time Indication: 0
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 47
Reset counter: 255
Mileage: 58224 km
Time Indication: 0
Date: 2014.07.03
Time: 10:44:33
Freeze Frame:
Fault Priority: 4
Reset counter: 28
Mileage: 65535 km
Time Indication: 0
Date: 2014.07.18
Time: 07:48:61
Any thoughts?
Cmmartin23
26
08-23-2016 04:44 PM
Raiden256
A6 (C7 Platform) Discussion
28
12-10-2015 02:50 AM
raiderrider
12
09-08-2015 05:46 AM
ajg617
09-06-2015 07:23 AM
bilbo6209
10
09-04-2015 04:07 PM
