Codes after replacing after-run coolant pump
Old 02-11-2010, 10:54 PM
huwla's Avatar
Default Codes after replacing after-run coolant pump
Had a shop recently replace the problematic after-run coolant pump. The car as 105K on the ticker and it was about time. Started to notice the coolant levels drop and noticable liquid on the garage floor. About a week after the work the check engine light came on. Popped on the Vag, below are the codes.
This seems like an interesting combination. 17965 implies a boost leak. Not surprising considering the shop had to remove the intake manifold to get to the after-run pump. The EGT sensors on this car suck; I've replaced two previously. However, the 'camshaft adjustment' code scares me. Never seen that one before. Never seen that one before. Any advice?
VAG-COM Version: Release 504.1-D
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 17 25 35 45 55 56
Address 01: Engine
Controller: 8D0 907 551 H
Component: 2.7l V6/5VT G 0003
Coding: 06711
Shop #: WSC 06435
4 Faults Found:
17866 - Exhaust Gas Temp Sensor 2 (G236): Short to Ground
P1458 - 35-00 - -
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-10 - - - Intermittent
17861 - Exhaust Gas Temp Sensor 1 (G235): Open or Short to Plus
P1453 - 35-10 - - - Intermittent
17930 - Camshaft Adjustment; Bank 2: Malfunction
P1522 - 35-10 - - - Intermittent
Readiness: 0000 0000
Old 02-12-2010, 04:41 AM
complacentsee's Avatar
My guess is the electrical connection/cable is tweeked after them removing the manifold.
Old 02-12-2010, 04:56 AM
thejulex's Avatar
All the codes could be due to electrical problem. Check if they didn't crush cable(s) between manifold and block...
Old 02-12-2010, 11:33 PM
huwla's Avatar
Any idea which side 'Bank 2' is on? Passenger or driver?
JaL3
34
03-24-2024 06:51 PM
MBL2.7t
07-22-2005 10:44 PM
GreekDeno
01-15-2004 08:55 AM
huwla
09-17-2003 04:38 AM
SteveJ_in_TX
02-25-2003 12:38 PM
Quick Reply: Codes after replacing after-run coolant pump
