Only one gear
#11
Good luck
oh ya, in the header of the reply section you'll see a paper clip, that attaches items. check it out
#12
So here's my occurred moment... I was thinking maybe that connecting rod has either popped off or has broken off. Either way, (here'e the kicker) you would be able to shift side to side... Hence your issue with only third gear. Why fourth doesn't go in.. well I can only imagine that's due to mal-adjustment from coming loose at the shift **** end. Not your fault but still needs to be adjusted. As for the connecting rod, that'd the thing to check amongst the rest of the other ideas. Still check that ball and socket I mentioned before, when I checked mine (cuz I was curious to y I had so much slop) I found that the socket was worn out and allowed tons of fore and aft movement... At my shifter, you can move it easily an inch before pushing it into a gear. So ya that's a ton of slop. Side to side is fine... funny how that is...
Chris
#13
Here is a video of what happens:
http://s45.photobucket.com/albums/f8...215f3b71ab.mp4
http://s45.photobucket.com/albums/f8...42c84dd1a4.mp4
Hopefully this will help.....
#14
If it's none of those, maybe something internally in the tranny. Hopefully not thou. And both shift rod and stabilizer rod are connected to the shifter? The reason why reverse seems like it goes in, is because in the shifter housing it locks into a groove until removed by the driver. So that's just throwing you off.
#15
I think I know what you mean by the connecting rod. It is the thin rod that connects the shifting rod and the stablizing rod and it connects over the top of the transmission. If that is broken to replace it does the trans have to be drop to get at it? More info tommorrow after I can get it up on jack stands.
#16
well
I'm looking to taking the shifter rod out myself to do the shifter rod's ball cup socket replacement. So sick of that slop.
The connecting rod bolts to the trans housing just as the stabilizing rod does too. Those two pieces are totally separated. So when you go to remove/replace the shifter rod, you'll remove the nut to the shifter rod bracket on the left side of the tranny, then remove the connecting rod bolt, on the right side of the tranny. Oh also another thing to keep in mind, when you get that shifter bracket out, there's that tiny shim that sometimes falls out and most ppl don't realize it. It maybe loose, if so you'll have to install it inside the bracket before putting the bracket back onto the tranny. And of course at the shifter it self you'll unbolt the shifter rod.
Then it's a matter of orchestrating it through the tight and bloody mess of other parts in the way. hahahahha.... Can't wait to do mine... sigh :.( lol
Chris
#17
Okay I have it up on jack stands and sure enough the bolt that holds the small bar that connects the stablizing rod and shifting rod together has come loose. And unfortunitly it came off on the passenager side. It's not broke or anything but I have no idea how I can get it back in place. If I have to lower the trans to just screw a bolt back in I am going to be pissed.....
#18
yup...
Believe me, I'm not looking forward to doing the same thing you gotta do, just to replace this stupid ball socket. grrr... Wish I just had my JHM Solid Short Throw Shifter. Do it once and be done with it.
#19
Guess what...you can attach the little cross over bar without lowering the craddle. What I ended up doing is pulling the intake and taking the cold air intake off.....then I was able to reach behind the motor and tighten it with an allen wrench....I will say that it took a bit and was hard on the hands and arms but it attached...loctite'd....and tight. Now for the next problem I have reverse and 1 through 4 but no 5th and 6th. I am trying to get the linkage adjusted right but I am having issue with that. The back is easy enough to get where I want it but the right to left isn't right. Now that the cross over bar is attached the shifter wants to stay all the way to the right. I think I need to get the shifter to move back to the left but I can't seem to get it there. All of the gears are to far to the right right now...
#20
I am still having problems...Once I reconnected the small crossover bar I haven't been able to shift into 5th or 6th. It seems like everything is moved to far to the right....Reverse is where 1st should be 1st is where 3rd should be and so on. Does anyone have any ideas for me? All the linkage looks correct, nothing is sloppy, or broken.
