Navigation Fails with Address Book Entries
#71
Exactly right for TT/TTS in my experience as well.
The newer MMI in the TT/TTS does not appear to work this way. The menu line for Directory is greyed out until the iPhone has sync'd with MMI (on each power up); after that all of my iPhone contacts are available in Directory - there is no "enter into directory" step. However, a few addresses still aren't usable - possibly the older ones, but I'm not sure.
Note that the Bluetooth settings for Audi MMI on the iPhone must have Sync Contacts enabled.
- Chuck
- Chuck
#72
Correct, the address has to be parsed and stored to the car's Directory first, but the steps are different for me and I have the same version MMI as you. I voice command the contact name, then select either the home or business address from the phone's contact at which point it gets immediately parsed. Then below the parsed address I select "Create entry in directory", which creates a shadow copy of the contact with the parsed address that's linked to the phone contact. From that point on, I can either select the parsed address to start navigation or use the "Navigate to...." voice command.
It appears the new MMI as found in the TT and 2016 C7 works differently as confirmed in earlier posts.
#73
- Chuck
- Chuck
While the terminology was a bit different and I left out the "private/business" selection, that's the same process I wrote in my post. It will also work without using voice command using the selector wheel.
#74
An example of the MMI contact parsing problem: "7700 Quattro Dr" is handled correctly, but "7700 Quattro Drive" is not. Looks like the built-in synonym table isn't quite complete...
(For those not in Minnesota, the above is a real address — Anderson Motorsport.)
- Chuck
- Chuck
DABearS4
01-30-2003 11:05 AM
