VAG-COM Discussion
Sponsored by:
Sponsored by:
level control sensor help
Old 07-01-2008, 02:24 PM
IanManchester's Avatar
Default level control sensor help
I had the following fault:
Address 55 -------------------------------------------------------
Controller: 4B0 907 357 B
Component: dynamische LWR D02
Coding: 00020
Shop #: WSC 02335
1 Fault Found:
00776 - Level Control System Sensor: Left Front (G78)
31-00 - Open or Short to Ground
so thought it would be the sensor, have purchased a new sensor - was having trouble unbolting the old one off so thought i would plug the new one in and clear the codes. Then ran vag com again this has however not made any difference. Any ideas?
Ian.
Old 07-02-2008, 03:08 PM
Theresias's Avatar
Default Checked the wiring yet?
<ul><li><a href="http://wiki.ross-tech.com/index.php/00776">http://wiki.ross-tech.com/index.php/00776</a</li></ul>
Old 07-13-2008, 04:22 AM
Default Re: Checked the wiring yet?
yep - took the front wheel off, and tested with a multimeter the + voltage and the - voltage going to the suspension sensor. These both seem to be ok.
I purchased a new sensor from audi a week or so ago - plugged that in (still getting error codes - so I believe the last thing it could be is the output wire from the sensor to the control module.
Using the measuring units on vag com I can seen the rear sensor is outputing approx 1.58/1.60 volts the front is outputing 0.02v.
I cant see where the wiring goes from the front wheel sensor to the control module - I dont know where the module is located on the car.
Any help anyone - thanks.
1 Bad DJ
VAG-COM Discussion
07-04-2019 03:17 PM
audijim113
12-12-2018 04:54 PM
infestdead
07-14-2014 07:23 AM
mart_o_rama
03-24-2013 11:26 AM
Blue2000S4
03-24-2010 08:52 AM
Quick Reply: level control sensor help
