Remote Key Matching
Remote Key Matching
Question on B7 RS4:
I cannot seem to get the memory seat matched to the key fob; i.e. mem position 1 to key 1 & mem position 2 to key 2.
I followed the instructions below but it doesn't seem to work. I cannot post measuring block info at the moment but will be happy to provide any requested info later this evening when I'm with the car.
Note: I successfully applied +00064 to [46] - Comfort System to get the windows to roll up and down from the key fob.
Channel 021: Remote Control Matching
[Select]
[46 - Comfort System]
[Adaptation - 10]
Channel 021.
[Read]
Choose the memory position you want the new key be matched on by entering it's number (e.g. "3" for memory positon 3).
[Test]
Now press any button on the remote you want to match.
The meas. block field above will change from Not Recogn. to Recognized.
[Save]
Thanks in advance.
[Select]
[Adaptation - 10]
Channel 021.
[Read]
[Test]
[Save]
Thanks in advance.
Do the remotes you have lock and unlock the car?
If so, the memory seat thing is a completely different issue. It's not done via diagnostics. Please refer to your owner's manual.
-Uwe-
-Uwe-
http://www.Ross-Tech.com
The 2 key fobs do lock and unlock the doors.....
I must have misunderstood this.. my apologies.. I thought this would match a specific key fob to a specific seat memory...
I'll go over the manual and look this up there.
Sorry...
PS. Is the one touch lock/unlock for all doors supported in the B7 - I used VAG on my B5/B6 to have all doors lock/unlock at the same time but can't seem to get that to work on the B7.
Any thoughts.
Thanks again for the help!
Sorry...
Any thoughts.
Yes, you should be able to turn off selective locking.
What's your current Comfort system coding?
-Uwe-<ul><li><a href="http://wiki.ross-tech.com/index.php/Audi_A4_%288E%29_Comfort_System#Coding">http://wiki.ross-tech.com/index.php/Audi_A4_%288E%29_Comfort_System#Coding</a</li></ul>
TighTT
Audi Original "S" Cars
09-16-2008 05:14 PM
derekcmoore
10-12-2006 06:34 AM
S4Senna
04-30-2002 08:45 PM
james shannon
10-16-2001 09:51 PM
