VCDS Faults Help
VCDS Faults Help
Hi guys
could you help with decipher the faults below ? I had a full scan done today and these 2 that came up .
2 Faults Found:
005661 - Glowplug for Cylinder 4 (Q13)
P161D - 001 - Open Circuit
Freeze Frame:
Fault Status: 01110001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 162573 km
Time Indication: 0
Date: 2006.03.19
Time: 07:17:59
Freeze Frame:
RPM: 882 /min
Torque: 140.4 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.98 V
Duty Cycle: 24.1 %
Temperature: 17.1°C
004195 - Fuel Pressure Regulation
P1063 - 004 - Control Range Not Reached - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 170723 km
Time Indication: 0
Date: 2015.06.03
Time: 13:16:01
Freeze Frame:
RPM: 819 /min
Torque: 89.7 Nm
(no units): 15.0
Voltage: 14.06 V
Pressure: 106.5 bar
Duty Cycle: 33.9 %
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 162573 km
Time Indication: 0
Date: 2006.03.19
Time: 07:17:59
Freeze Frame:
RPM: 882 /min
Torque: 140.4 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.98 V
Duty Cycle: 24.1 %
Temperature: 17.1°C
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 170723 km
Time Indication: 0
Date: 2015.06.03
Time: 13:16:01
Freeze Frame:
RPM: 819 /min
Torque: 89.7 Nm
(no units): 15.0
Voltage: 14.06 V
Pressure: 106.5 bar
Duty Cycle: 33.9 %
Audiworld Premium Sponsor
An intermittent fault means that at the time of the scan, the fault was no longer present. I would clear the fault and see if it recurs.
-Bruce-
Ross-Tech, LLC
-Bruce-
Ross-Tech, LLC
I never suggested changing the glow plug. I suggested that you check the resistance and the wiring. Throwing parts at problems is the expensive way to fix the car.
As to the intermittent fuel pressure, my guess is you have a fuel pressure pump that is in the process of failing - or the regulator is in the process of failing. That it is intermittent and if you are not seeing any other problems, my reaction would be to leave it be for now but to start searching for what might be the cause in that system. i would be prepared for the car to fail in the near future.
Fuel pressure problems should manifest in reduced performance - the fuel delivery not keeping up with the demand.
-Bruce-
Ross-Tech, LLC
-Bruce-
Ross-Tech, LLC
update
so i have checked the faults again and only 1 came back
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F0 910 402 D HW: 4F0 907 401 C
Component: 3.0L V6TDI G000AG 0020
Revision: --H03--- Serial number:
Coding: 0011372
Shop #: WSC 02334 785 00200
VCID: 1E3338FAC917D8EE86F-804B
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 171961 km
Time Indication: 0
Date: 2015.06.25
Time: 06:47:10
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 11.70 V
Duty Cycle: 15.0 %
Temperature: 19.8°C
Readiness: 0 0 0 0 0
any ideas ?
Coding: 0011372
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 171961 km
Time Indication: 0
Date: 2015.06.25
Time: 06:47:10
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 11.70 V
Duty Cycle: 15.0 %
Temperature: 19.8°C
any ideas ?
You asked for suggestions, Bruce gave you the same suggestion I would. You waited, pulled only one code and asked for suggestions again.
You didn't mention if you followed Bruce's advice and checked the wiring/glow plug, was that done?
dariusps3
12
11-27-2022 06:05 AM
thegaffer
Q7 MK 1 Discussion
04-27-2014 07:41 AM
