TPMS Malfunction - Help!
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01
Revision: 00010028 Serial number: 00000700033953
Coding: 0232125
Shop #: WSC 00000 785 00200
VCID: DFC73DA50E263D1
1 Fault Found:
01521 - Sensor for Tire Pressure
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 142
Mileage: 129369 km
Time Indication: 0
Date: 2013.08.26
Time: 16:48:50
Freeze Frame:
Speed: 0.0 km/h
Temperature: 34.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Scroll through module [65] and you will see it in the plain text description window.
The number of months is remaining per Seb @ Ross-Tech: https://www.audiworld.com/forums/sho....php?t=2810739
EDIT: Also check the frequency matches per the Ross-Tech Wiki http://wiki.ross-tech.com/wiki/index...itoring#Coding
Add'l info: http://wiki.ross-tech.com/wiki/index.php/01521
Last edited by jakematic; Aug 27, 2013 at 06:51 AM. Reason: additional information
