Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
need help with wheel spacer
Old 08-19-2014, 01:57 PM
baubau2.7's Avatar
Default need help with wheel spacer
Ok, so I got a newer set of wheels: ALY58851 Audi A6 10 spoke wheel, Bolt Pattern: 112mm Offset: 48mm Audi Part Number: 4F0601025CP with tires 245/40 r 18 Conti's.
My OEM wheel was ET43, with 235/40R18 tires.
I Installed one wheel on the front and it is rubbing.
My question is what wheel spacer size I need:
- 5 mm the difference of offset, or
-10 mm too make up for the wider tire?
thanks
Old 08-19-2014, 03:20 PM
AudiWorld Expert
Reggie's Avatar
I suspect that 5mm will work as it will push your offset to 48. You might post this on the A6 forum as there will be people there with experience.
Old 08-25-2014, 08:54 PM
mishar's Avatar
thanks
Where is it rubbing? To the knuckle? Tire or rim? How wide are old rims?
Old 09-01-2014, 07:17 AM
baubau2.7's Avatar
The tire is rubbing on the knuckle
The old rims were 8" wide.
Old 09-01-2014, 05:00 PM
mishar's Avatar
I would suggest 10 mm spacer to allow for some tire deformation.
baubau2.7
08-16-2014 09:22 PM
Hockenheim
10
03-12-2014 10:03 AM
B6SilverS4
04-11-2006 08:51 AM
aca
10-01-2004 06:14 PM
dolphizzle gray
11-10-2003 10:57 PM
Quick Reply: need help with wheel spacer
