2005 Audi 1.8t 20v misfire problems
Well ever since last year I’ve been working on my Audi about “check coolant levels switch engine off” So I felt like replace almost the whole engine.
What I had replace is;
water pump how it all started.
Thermostat
which lead to crack cylinder head an worn out vavels gaskets.
So bought a 300$ Volkswagen well put together cylinder head.
New gaskets on cylinder an cylinder heads and intake an exhaust.
Replace alternator
replace battery.
and new coolant flange.
as I start my car, when idle, it roughly shakes. I’ve Read the codes became a misfire problems on all cylinders.
So it over heats as well. Coolant signal goes off still. Coolant evaporates while driving. So still an overheating problem. I even switch my spark plugs change my intake filter. Still having over heating/misfire/roughly idle problems/evaporating coolant. Their are no leaks. And my cat is gone bad. Air stat off don’t know if that’s normal. It’s been really hard to figure it out.
Thermostat
Replace alternator
replace battery.
ginni008
A4 (B7 Platform) Discussion
04-08-2013 11:38 PM
