2111 error code when started
Old Aug 15, 2011 | 08:20 AM
OPAudi's Avatar
Default 2111 error code when started
I am having an issue with the '95 90 Quattro...
It starts great and runs smooth...most of the time. However, sometimes it will surge from 2k rpm down to 500 rpm when holding the gas pedal in the same position. It will run just fine after revving it to 3-4k or after turning it off and restarting altogether.
I checked the fault codes while the engine is running and it's showing 2111, which 12v.org says is ok to ignore if the engine is off when you check it. Otherwise, it says it's the "vehicle speed sensor".
Anyone had this problem or know what the actual cause could be? Catalytic converter? Injection? Bad air filter? Anything?
Old Aug 15, 2011 | 08:22 AM
OPAudi's Avatar
Also, the oil pressure it around 70. Is that about where it should be?
I normally drive Jeeps which run much higher and are a completely different monster..lol.
Old Aug 16, 2011 | 06:38 AM
grillage's Avatar
Did you try this stuff?
Old Aug 18, 2011 | 06:19 AM
OPAudi's Avatar
Will check those sensors, but the car starts and just sorta chokes but hasn't really ever died.
Looking into an air filter system issue to see if that has anything to do with it. It needs a new exhaust which I'm getting replaced this week and as soon as that is done, I'll start inspecting sensors.
Old Dec 1, 2011 | 02:59 PM
DCarpy's Avatar
I have the same car with a similar problem. I just learned how to pull the codes from that same website, although the procedure seemed a bit different for my car. I would only get a code after removing the jumper wire, and then to get further codes I would jump it and remove it again. At first i was getting the 2111 code also, but then later was able to pull more codes once I figured this out.
Carpoof
12
May 3, 2017 07:44 PM
makav3li
Mar 25, 2010 03:25 AM
o1A4
Chicago Discussion
Sep 16, 2004 07:07 PM
TTinGables
11
Oct 1, 2001 05:51 AM
Robjared
Misc. Models Discussion
Jun 24, 2001 05:55 PM
