FYI: ECU coding (MMS 200, 300, 311) euro coding, EGR problems go away (if you don't need EGR)...
This from the Bentley manual for 1993-95 90
If you do a search for "function 07" in the Bentley manual you will find how to RE-code your ECU to many diffirent parameters ex: no EGR, euro code... etc.
Unfortunately for the MMS 200 there is no software coding, you have to ground couple pins on the ECU it self. (which is what I have)
For MMS 300 and 311 you can use function 7 of vag software to code the ECU that you want.
The following is for MMS 200
Code Control Module (VAG 1551 function 07)
The VAG 1551 Scan Tool must display a four-digit code during Control Module identification.
The factory performs ECM coding in the wiring harness at connectors B and C of the ECM.
The first three digits are coded via terminals 14, 16 and 19 of connector B and the fourth digit via terminal 9 of connector C.
If one of these terminals is connected to Ground a zero is displayed; if this terminal is not occupied (open), a 1 is displayed in the appropriate position of the code.
Example
Coding 1 1 1 1
Connector B B B C
Terminal 14 16 19 9
- If VAG 1551 Scan Tool does not display appropriate coding for vehicle ( page 01-59 ), check ECM terminal assignment using wiring diagram.
- If incorrect terminal assignment is determined, correctly install terminals in connectors B or C using wiring diagram.
- If terminal assignments are correct, replace ECM.
ECM coding table - equipment combinations
Coding
Vehicle equipped with:
Vehicle NOT equipped with:
1010
Manual transmission
Exhaust Gas Recirculation (EGR)
1111
Manual transmission, EGR
EGR temperature sensor
1011
California version with manual transmission, EGR and EGR temperature sensor
1110
ECE version
Heated Oxygen Sensors (HO2S), EVAP canister purge regulator valve, EGR
0010
Front wheel drive and automatic transmission
EGR
0111
0011
California version with front wheel drive and automatic transmission, EGR and EGR temperature sensor
0110
ECE version with front wheel drive and automatic transmission
HO2S, EVAP canister purge regulator valve, EGR
Coding
1000
Quattro with automatic transmission
EGR
1101
Quattro with automatic transmission, EGR
1001
California version quattro with automatic transmission, EGR and EGR temperature sensor
1100
ECE version quattro with automatic transmission
0000
0001
0100
0101
DTC coding
Example
Coding 1 1 1 1
Connector B B B C
Terminal 14 16 19 9
Coding
1010
Manual transmission
1111
1011
1110
ECE version
0010
EGR
0111
0011
0110
Coding
1000
EGR
1101
1001
1100
0000
0001
0100
0101
DTC coding
digging in the archives
Digging up a really old post here!
Who can tell me what ECE version is? coding 1110
i have a audi 80 quattro 2.8 aah and i want to turn off everything, as per
1110
ECE version
i have performed similar coding using a mms300, however need to now use a mms200 for ship purposes
any ideas? is 1110 the correct coding im after?
thanks for any help
1110
ECE version
thanks for any help
N'Syncro
33
02-16-2020 03:12 PM
CPLYONS
09-07-2015 07:19 PM
ECS Tuning-Audi
09-01-2015 12:25 PM
