Manual transmission/differential fluid - where can I get it?
When I put my car into understeer situations, there seems to be some kind of rapid clunking from the front-center of the car. YES, I'm sure its not my ABS working. I don't know if its some sort of traction control issue - I'm unaware that our cars had ESP/TCS of any sort. No, I don't think the shocks are bottoming out - not enough body lean/I'm testing this on a flat surface, and the noise is coming from the wrong place.
Could this be a sign of differential fluid getting old? If so, where can I buy the appropriate tranny/diff fluid? (Center/Front diff and manual tranny take the same fluid apparently) I've looked on autohausaz and haven't been able to find anything. It's a 5-speed.
Note that the car has about 165kmi on it and I have no idea when the lubricant in the transmission was last changed. I got the car at 134kmi and didn't start working on it till 148kmi. Judging by the condition that the car was in when I bought it, I have little confidence in the previous owner. Maintenance was probably done by the dealer at stretched intervals if at all.
This is what I used just 1 1/2 hours ago.........................................
Motul Gear 300<ul><li><a href="http://www.motorspot.com/">http://www.motorspot.com/</a</li></ul>
Red Line MT-90 (GL-4) works well for me
If you are in a colder climate than me (temperate coastal climate), a mix of MT-90 and the thinner MTL may be better.
In the rear differential I have been using Red Line 75-90 (GL-5). Don't forget to change the fluid in the rear differential. You will likely see a lot of "glitter."
I find Red Line locally at various auto parts shops.
BAEL
Audi A3 / S3 / RS 3
10
02-15-2008 10:40 PM
salpinx
04-28-2006 06:46 AM
bklyngene
06-22-2004 08:52 AM
thermonuclear
05-21-2002 08:16 PM
