velocity stack
One-sided razor blade--one easy, nice, clean, straight cut and then trim the bottom off
I just took it out of a box-cutter (from my handi-dandy airplane hijack kit :-P) and then pressed it through the rib by hand. I would not use anything with a handle--not enough room. However, the sharp chisle also sounds like a good idea.
Re: One-sided razor blade--one easy, nice, clean, straight cut and then trim the bottom off
if you can get 5 men to surround and hold the airbox securely while you do the cutting, mission should be accomplished..
bilbo6209
09-09-2015 01:28 PM
The Bald Marmot
06-08-2001 11:42 AM
WYSIWYG
03-05-2001 07:47 AM
WYSIWYG
02-19-2001 09:25 AM
