Alternator issue's
Alternator issue's
I already have the replacement. Yes it's due, I have 106k miles. I was just wondering why...when I start the car the Alt is making 13.7 volts. It starts slowly going down. 13.69 68 67 and so forth. It levels off about 12.8 unless you turn something on. It always starts. It just bothers me. Any idea's?
Voltage regulator should reduce output if the battery is being recharged and there are no other
demands on the system. Now if the voltage increases when you turn on the A/C and fan then I would think it is working properly. When I have had alternators fail in the past, the voltage output could not keep up with accessories and the voltage would gradually drop unless the engine were revving pretty high, but even then it would not put out enough voltage to properly recharge the battery and run the other systems needing electric power. How quickly does it drop down to 12.8V? Is your battery fully charged (12.6V several hours after driving)? Sounds like a weak alt to me, but I haven't taken readings lately on a good one - my dash Voltmeter usually reads mid 13's at steady state.
our alternators suck (as in suck in a lot of heat from the engine) and therefore aren't very
efficient during the summer.
Usually, when I start my car I'm over 14 volts. During driving I'll get down to 13.x volts due to heat (no engine load due to A/C or headlights or etc.)
Honestly, at 106k miles, you've probably used up all of your brushes and they need to be replaced.
IamR.Ph.
02-04-2011 03:59 AM
Killer00S4
07-17-2006 05:25 AM
RussB
01-13-2005 01:17 PM
