couple of piggie pipe questions? getting ready to diy
Ive read the diy in the archive forum but im trying to figure out is there a non cutting method? or should i just cut them and weld them back up? and where do the rear o2's go from what i found they go behind the main cats. will i still throw codes? Then i came across anti foulers which i have no idea what they do. maybe for running no cats. Im getting another set of stock dps so i can swap them out when i want. i have access to a lift so it shouldnt be to hard
you could try ramming the catalytic converter material out, but you'd never
be able to get it all out. cutting is the "cleanest" method.
antifoulers keep you from having rear O2 codes
I wrote this some time ago...hope it helps.
<center><img src="https://www.audiworld.com/tech/pics/eng75_finished.jpg"></center><p>
<ul><li><a href="https://www.audiworld.com/tech/eng75.shtml">https://www.audiworld.com/tech/eng75.shtml</a</li></ul>
Wrinkledpants
Rocky Mountain Discussion
9
09-23-2008 07:37 AM
SNogaro4
06-04-2007 06:42 PM
-M3=Lunch-
07-21-2004 10:30 AM
