x-post. what do you guys think about the following codes i pulled...
it rides well after the clearing. but i do get a hiccup now and then. but no cels or esp off light. so here is the report, let me know on your input on what i need to look out for:
VCDS Version: Release 805.1
Data version: 20080823
Monday,13,October,2008,18:36:31:13274
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
76 77
VIN: WAULD64*****************
Address 01: Engine
Control Module Part Number: 4B0 907 551 AL
Component and/or Version: 2.7l V6/5VT G 0001
Software Coding: 06752
Work Shop Code: WSC 79927
Additional Info: WAULD64B02N051338 AUZ7Z0A1939502
3 Faults Found:
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-10 - - - Intermittent
16487 - Mass Air Flow Sensor (G70): Signal too High
P0103 - 35-10 - - - Intermittent
16805 - Warm Up Catalyst; Bank 1: Efficiency Below Threshold
P0421 - 35-10 - - - Intermittent
Address 02: Auto Trans
Control Module Part Number: 4B0 927 156 DR
Component and/or Version: AG5 01V 2.7l5VT USA 1819
Software Coding: 01032
Work Shop Code: WSC 00000
1 Fault Found:
18265 - Load Signal: Error Message from ECU
P1857 - 35-10 - - - Intermittent
Address 03: ABS Brakes
Control Module Part Number: 4B0 614 517 H
Component and/or Version: ABS/ESP allrad 1728
Software Coding: 06397
Work Shop Code: WSC 02325
1 Fault Found:
Address 06: Seat Mem. Pass Labels: None
Part No: 4B0 959 760 C
Component: Sitzmemory R1 BF 0102
Coding: 00003
Shop #: WSC 00000
No fault code found.
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 4B0 820 043 AD
Component: A6-Klimavollautomat 0105
Coding: 00010
Shop #: WSC 02325
Address 15: Airbags Labels: None
Part No: 4B0 959 655 N
Component: Airbag 8.4E 3001
Coding: 0000307
Shop #: WSC 02325 785 00200
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No: 4B0 907 487 J
Component: Lenkradelektronik D01
Coding: 01012
Shop #: WSC 02325
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 981 P
Component: KOMBI+WEGFAHRS. VDO D09
Coding: 02264
Shop #: WSC 00000
WAULD64********** AU************
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 J
Component: Central Lock/Alarm D35
Coding: 15981
Shop #: WSC 02325
5 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01562 - Right Rear Door
59-10 - Can't Unlock - Intermittent
01573 - Alarm triggered by Door Contact Switch; Left Rear
35-00 - -
Address 36: Seat Mem. Drvr Labels: None
Part No: 4B0 959 760 B
Component: Sitzmemory R1 F 0101
Coding: 00001
Shop #: WSC 00000
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 P HW: 8E0 035 192 P
Component: RNS-E US3 H74 0200
Revision: 03S Serial number: AUZBZ7G2403985
Coding: 0301117
Shop #: WSC 06325 000 00000
4 Faults Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 5
Reset counter: 177
Time Indication: 0
Date: 2008.07.14
Time: 17:32:30
Freeze Frame:
Voltage: 12.00 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
00858 - Connection; Radio ZF Output to Antenna Amplifier
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 5
Reset counter: 176
Time Indication: 0
Date: 2008.07.14
Time: 17:37:12
Freeze Frame:
Mileage: 655350 km
Count: 1310
Clock: 17:34
00852 - Loudspeaker(s); Front
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 2
Reset counter: 111
Time Indication: 0
Date: 2008.05.17
Time: 11:47:48
01317 - Control Module in Instrument Cluster (J285)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 85
Time Indication: 0
Date: 2008.05.17
Time: 11:48:09
Freeze Frame:
Bin. Bits: 11011011
Bin. Bits: 11
Address 45: Inter. Monitor Labels: None
Part No: 4B0 951 178 A
Component: Innenraumueberw. D04
Coding: 00101
Shop #: WSC 02325
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D06
Coding: 00050
Shop #: WSC 02325
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0301117
4 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 177
Time Indication: 0
Date: 2008.07.14
Time: 17:32:30
Freeze Frame:
Voltage: 12.00 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
Freeze Frame:
Fault Priority: 5
Fault Frequency: 5
Reset counter: 176
Time Indication: 0
Date: 2008.07.14
Time: 17:37:12
Freeze Frame:
Mileage: 655350 km
Count: 1310
Clock: 17:34
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 111
Time Indication: 0
Date: 2008.05.17
Time: 11:47:48
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 85
Time Indication: 0
Date: 2008.05.17
Time: 11:48:09
Freeze Frame:
Bin. Bits: 11011011
Bin. Bits: 11
Address 76: Park Assist Labels: 8Z0-919-283.lbl
Part No: 8Z0 919 283
Component: Parkingsyst. A6 USA D08
Coding: 01126
Shop #: WSC 02325
End ---------------------------------------------------------------------
76 77
Address 01: Engine
3 Faults Found:
1 Fault Found:
1 Fault Found:
Coding: 00003
Shop #: WSC 00000
Coding: 00010
Shop #: WSC 02325
Coding: 0000307
Coding: 01012
Shop #: WSC 02325
Coding: 02264
Shop #: WSC 00000
Coding: 15981
Shop #: WSC 02325
5 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
Coding: 00001
Shop #: WSC 00000
Coding: 0301117
4 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 177
Time Indication: 0
Date: 2008.07.14
Time: 17:32:30
Freeze Frame:
Voltage: 12.00 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
Freeze Frame:
Fault Priority: 5
Fault Frequency: 5
Reset counter: 176
Time Indication: 0
Date: 2008.07.14
Time: 17:37:12
Freeze Frame:
Mileage: 655350 km
Count: 1310
Clock: 17:34
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 111
Time Indication: 0
Date: 2008.05.17
Time: 11:47:48
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 85
Time Indication: 0
Date: 2008.05.17
Time: 11:48:09
Freeze Frame:
Bin. Bits: 11011011
Bin. Bits: 11
Coding: 00101
Shop #: WSC 02325
Coding: 00050
Shop #: WSC 02325
Coding: 0301117
4 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 177
Time Indication: 0
Date: 2008.07.14
Time: 17:32:30
Freeze Frame:
Voltage: 12.00 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
Freeze Frame:
Fault Priority: 5
Fault Frequency: 5
Reset counter: 176
Time Indication: 0
Date: 2008.07.14
Time: 17:37:12
Freeze Frame:
Mileage: 655350 km
Count: 1310
Clock: 17:34
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 111
Time Indication: 0
Date: 2008.05.17
Time: 11:47:48
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 85
Time Indication: 0
Date: 2008.05.17
Time: 11:48:09
Freeze Frame:
Bin. Bits: 11011011
Bin. Bits: 11
Coding: 01126
Shop #: WSC 02325
EuroVWGTi
10-13-2008 04:02 PM
