oil grade
Old 12-18-2018, 12:45 PM
wingdiver's Avatar
Default oil grade
what is the recommended oil grade for the 2019 q7?
Old 12-18-2018, 12:50 PM
uberwgn's Avatar
Wing, what country are you writing from? What engine?
Welcome aboard !!
Old 12-18-2018, 01:02 PM
wingdiver's Avatar
Thanks Uberwgn, I'm writing from the US, east coast and my engine is the 3.0l
Old 12-18-2018, 01:17 PM
uberwgn's Avatar
The required oil will be either quality standard 504.00 or 502.00. You need to open the hood and there will be a label just above where the radiator sits in the car. That will call out which VAG spec they want you to use. The 502.00 oils are e-z to track down.
Old 12-18-2018, 01:27 PM
wingdiver's Avatar
Thank you again for your help.!!
Old 12-18-2018, 01:28 PM
uberwgn's Avatar
My pleasure.
Old 12-22-2018, 01:05 PM
angrypengu's Avatar
Are you absolutely sure the Q7 doesn't have the EA839 engine that requires 508.00?
Old 12-22-2018, 03:51 PM
wingdiver's Avatar
No,my Q7 has the 3.0L engine and on top of the radiator I found the two stickers with the recommended oil grade 504.00 and 502.00. After some research I found that one is a 5w30 and the other is a 5w40 grade. I’m still confused why Audi gives me a choice of 2 grades of oil for this engine.
Old 12-22-2018, 03:53 PM
angrypengu's Avatar
In that case my suggestion by far is German Castrol 0w30 which is 50200 approved.
Old 12-22-2018, 04:04 PM
wingdiver's Avatar
Is that The Castrol Syntec European Formula? Where can I buy it? Audi dealer?
Quick Reply: oil grade
