Still Misfiring After Injector replacement, gasket replacement, pcv etc
Hello All.
I have 2007 VW Touareg 4.2 V8 FSI - BAR Engine (same as in the Audi Q7 4.2 V8). I have had multiple cylinder misfires for the last 6 or so months. I have done several things to try and fix the problems but I am still having misfires. I noted that after the changes on 30th June 18 the misfires changed to 'Intermittent' status. As the issues seems to be only on 1 side i.e. Cylinders 1, 2 & 4 could it be the High Pressure Fuel Pump that needs replacing?
The car starts up and essentially idles roughly and if you try and accelerate the engine dies.
What I have done so far in exact order (all OEM parts):
1.) Changed all Vacuum Hoses/Pipes (15 June 18 VCDS scan done after this change attached)
3.) Changed all Spark Plugs & Coils (15 June 18 VCDS scan done after this change attached)
4.) Changed PCV valve (15 June 18 VCDS scan done after this change attached)
5.) Changed MAFs both sides (15 June 18 VCDS scan done after this change attached).
6.) Changed ALL 8 injectors (30 June 18 VCDS scan done after this change attached)
7.)Changed Intake Manifold Gaskets and did carbon cleaning (30 June 18 VCDS scan done after this change attached)
8.) Changed Valve Cover Gaskets (30 June 18 VCDS scan done after this change attached)
9.) Changed Fuel tank Filter (30 June 18 VCDS scan done after this change attached)
As per attached VCDS scans done on 30 June 18 I still have 'Intermittent Misfires on Cylinders 1, 2 and 4'
Any thoughts ideas? Do I need to change the High Pressure Fuel Pumps?
VCDS
Self-Diagnosis Log Saturday,30,June,2018,18:51:45:20387
Page 2
VIN: WVGZZZ7LZ7D068231 License Plate: KBZ 880T
Address 01: Engine Labels:. 079-907-560-BAR.clb Part No SW: 7L0 907 560 A HW: 7L0 907 560
Component: 4.2l V8/4V 0030
Revision: 75H04--- Serial number: VWX3Z0F6536655 Coding: 04210003590F0560
Shop #: WSC 31414 790 00001 VCID: 2F6D7640BD52EF3C8E-515E
4 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected P0300 - 001 - - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 93622 km
Time Indication: 0
Date: 2018.06.30
Time: 18:37:46
Freeze Frame:
RPM: 598 /min
Load: 60.4 %
Speed: 0.0 km/h Temperature: 27.0°C Temperature: 21.0°C Absolute Pres.: 810.0 mbar Voltage: 14.224
V
000769 - Cylinder 1
P0301 - 001 - Misfire Detected - Intermittent Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 93622 km
Time Indication: 0
Date: 2018.06.30
Time: 18:37:46
Freeze Frame:
RPM: 598 /min
Load: 60.4 %
V
000772 - Cylinder 4
VCDS
Page 3
P0304 - 001 - Misfire Detected - Intermittent Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 93622 km
Time Indication: 0
Date: 2018.06.30
Time: 18:37:46
Freeze Frame:
RPM: 598 /min
Load: 60.4 %
V
000770 - Cylinder 2
P0302 - 001 - Misfire Detected - Intermittent Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 93622 km
Time Indication: 0
Date: 2018.06.30
Time: 18:37:46
Freeze Frame:
RPM: 598 /min
Load: 60.4 %
V
Readiness: 0110 1101
VCDS SCAN Done on 15 June 18:
VCDS
Self-Diagnosis Log Friday,15,June,2018,09:37:22:20387
Page 2
Shop #: WSC 31414 790 00001 VCID: 2F6D7640BD52EF3C8E-5140
5 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected P0300 - 001 - - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 93622 km
Time Indication: 0
Date: 2018.06.10
Time: 12:10:26
Freeze Frame:
RPM: 899 /min
Load: 82.3 %
Speed: 0.0 km/h Temperature: 26.0°C Temperature: 19.0°C Absolute Pres.: 820.0 mbar Voltage: 13.970
V
000769 - Cylinder 1
P0301 - 001 - Misfire Detected - MIL ON Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 93622 km
Time Indication: 0
Date: 2018.06.10
Time: 12:10:26
Freeze Frame:
RPM: 899 /min
Load: 82.3 %
V
000771 - Cylinder 3
VCDS
Page 3
P0303 - 001 - Misfire Detected Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 93622 km
Time Indication: 0
Date: 2018.06.10
Time: 12:10:26
Freeze Frame:
RPM: 899 /min
Load: 82.3 %
V
000770 - Cylinder 2
P0302 - 001 - Misfire Detected Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 93622 km
Time Indication: 0
Date: 2018.06.10
Time: 12:10:26
Freeze Frame:
RPM: 899 /min
Load: 82.3 %
V
000772 - Cylinder 4
P0304 - 001 - Misfire Detected Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 93622 km
Time Indication: 0
Date: 2018.06.10
Time: 12:19:39
VCDS
Page 4
Freeze Frame:
RPM: 797 /min
Load: 44.7 %
Speed: 0.0 km/h Temperature: 28.0°C Temperature: 20.0°C Absolute Pres.: 820.0 mbar Voltage: 14.097
V
New Injector
Old Injectors
VCDS
Page 2
4 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 93622 km
Time Indication: 0
Date: 2018.06.30
Time: 18:37:46
Freeze Frame:
RPM: 598 /min
Load: 60.4 %
V
000769 - Cylinder 1
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 93622 km
Time Indication: 0
Date: 2018.06.30
Time: 18:37:46
Freeze Frame:
RPM: 598 /min
Load: 60.4 %
V
000772 - Cylinder 4
VCDS
Page 3
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 93622 km
Time Indication: 0
Date: 2018.06.30
Time: 18:37:46
Freeze Frame:
RPM: 598 /min
Load: 60.4 %
V
000770 - Cylinder 2
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 93622 km
Time Indication: 0
Date: 2018.06.30
Time: 18:37:46
Freeze Frame:
RPM: 598 /min
Load: 60.4 %
V
VCDS
Page 2
5 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 93622 km
Time Indication: 0
Date: 2018.06.10
Time: 12:10:26
Freeze Frame:
RPM: 899 /min
Load: 82.3 %
V
000769 - Cylinder 1
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 93622 km
Time Indication: 0
Date: 2018.06.10
Time: 12:10:26
Freeze Frame:
RPM: 899 /min
Load: 82.3 %
V
000771 - Cylinder 3
VCDS
Page 3
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 93622 km
Time Indication: 0
Date: 2018.06.10
Time: 12:10:26
Freeze Frame:
RPM: 899 /min
Load: 82.3 %
V
000770 - Cylinder 2
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 93622 km
Time Indication: 0
Date: 2018.06.10
Time: 12:10:26
Freeze Frame:
RPM: 899 /min
Load: 82.3 %
V
000772 - Cylinder 4
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 93622 km
Time Indication: 0
Date: 2018.06.10
Time: 12:19:39
VCDS
Page 4
Freeze Frame:
RPM: 797 /min
Load: 44.7 %
V
New Injector
Old Injectors
Rough Idle & Going Off - No Misfires
Hey AudiWorld Forum Memebers,
So an update on my ongoing problems....
So I gave it a 2nd try on the carbon cleaning, which went well in my opinion. So no more engine misfire errors, those seem to have cleared. However I am not getting rough idle on startup and then the car goes off if you try to accelerate.
So what I have changed and done so far:
1.) All Spark Plugs and Coils - OEM
2.) Intake Manifold Gaskets - OEM
3.) Valve Cover Gaskets - OEM
4.) PCV - OEM
5.) All 8 injectors - Hitachi
6.) High Pressure Fuel Pumps - both left and right - OEM for the BAR engine
7.) Fuel Pump, Fuel Filter & Fuel Pressure Regulator under the back seats - VDO
8.) Vacuum Pipes - OEM
9.) Throttle Body - Bosch & I did the Throttle Body Adaptation Procedure as per VCDS and it worked/passed
10.) New Complete Intake Manifold - OEM (mechanic suspected stuck intake manifold flaps) - did Throttle Body Adaptation procedure as per VCDS after fitting new Intake Manifold and it worked/passed
11.) While we had the intake manifold off - changed the double o-rings under the oil filter housing.
So what next? I am getting the same symptoms car starts, rough idle then goes off.
Is there any idling rest procedure/adaptation that I need to do? Since I am not getting any mis-fire errors, could it be that after changing the
4.) PCV - OEM
Not sure exactly how they cleaned them, I know they basically dismantled the exhaust system including the catalytic converters, then shook out a lot of the clogged gunk, and 'I think' they did some chemical cleaning. I also found out later that they drilled holes in the catalytic converters.
The car runs and drives well after all that, however because they drilled hole(s) I am getting 2 error codes:
001073 - Warm Up Catalyst; Bank 2
P0431 - 002 - Efficiency Below Threshold - MIL ON
001057 - Warm Up Catalyst; Bank 1
P0421 - 002 - Efficiency Below Threshold - Intermittent
I found out about the holes being drilled later on when I took the car back to indicate those 2 faults, and the dealer then told me that they drilled the holes and those apparently could be the cause of the 2 error codes. To solve the errors the dealer indicates I need to buy 2 new catalytic converters and replace.
Caveat...this was done in Nairobi, Kenya - VW dealer so we do not have the same stringent rules regarding emissions etc that may apply in other countries.
