Valentine One hardwire
This is the walkthrough I followed and had my V1 installed the day after I took delivery.
https://www.audiworld.com/forums/audi-a5-s5-rs5-coupe-cabrio-b9-220/2018-a5-sportback-hardwire-radar-detector-2932679/#post25039165
https://www.audiworld.com/forums/a4-b9-platform-discussion-212/radar-detector-hardwire-diy-2906758/
It will take some effort tucking the cable at the top of the headliner where the A-pillar joins together due to the very tight tolerances, but you can massage it into place so the wires are not seen. Be prepared to have bleeding fingernails if you do not have a plastic pry tool.
Additional effort was made to tap into the fusebox located behind the dead pedal. The actual fuses are tucked down in between plastic columns, and you will have to force the fuse tap wiring in between the columns and quickly reinstall the dead pedal for it to stay in place. You will see what I mean when you take the dead pedal cover off. Before tidying everything up, make sure the detector powers on.
I am usually able to hardwire my V1 in any other vehicle in less than 10 minutes. The Audis generally take me some extra effort because of the tight tolerances.
Honestly, I do not recall.
I think so, but I found that the other fuses near the bottom were also non-essential and easier to tuck the wiring so I may have used one of those instead.
You want to make sure the fuse tap is something that is only on ignition on and non-critical (e.g. HomeLink or seat warmers).
You can tap into ignition switched power from the fuse box left of the dash. As the V1 has an in-line fuse there is no need to buddy off another circuit, probe around and you will find switched power. You will need this to keep the V1 from going nuts during engine restarts- BOB V1 Radar Detector Option | Valentine One | Radar Detectors. The A-pillar cover comes off easily, but if you are hesitant to remove it you can pull the weather stripping and tuck the wiring in from behind. Another alternative is using a mirror tap- https://www.blendmount.com/mirrortap.html
Curious why everyone is running a wire all the way down the windshield when you can tap into the rear view mirror...? Am I missing something?
https://store.blendmount.com/mobile/mirrortap-1000-series-080-tap-radar-detector-power-cord-with-inline-fuse-15-long-p1524.aspx
sinoangtataymo
05-05-2003 07:45 PM
KraZyS4
10-07-2002 12:57 PM
blakeh
07-18-2001 06:00 AM
