Whistle sound at low speeds on 2017 Premium Plus
#11
Very interesting! Do you have any idea what conditions will make it happen more? Is it cold weather related, or did I just completely miss it happening all the time during the first few months I owned the car?
#12
Same noise but doesn't bother me HOWEVER, I do have these random "popping, crackling" noises coming from the passenger side window/door or roof area when driving. Sounds like interior door/wall panels is contracting/expanding due to climate or not securely fastened? Does anyone else have this issue? Really annoying.
#13
If monitoring with VCDS, I would expect to see the voltage increase when I hear that noise presumably?
#14
Same here! As this being my first Audi I really didn't expect it to pop and crack so much. I brought my 2018 Premium Plus into the dealer 3 times already, they found panel loose on passenger side door, and an interior panel on D pillar misaligned. The dealer insists the rest of the popping and cracking is "normal" so I guess I just have to live with it.
#15
It's a function of the new DSG transmission Audi is using on the MLBs. From what I understand the pump cycles on and off, the condition being the accumulator pressure is kept around ~27 bar/400 psi. Because DSG fluid expands as it heats up the pump should run more often when it's cold and less often as the fluid warms up, however the accumulator also discharges as the transmission shifts gears/works the clutches so that can also affect how often the pump needs to come on.
#16
Is this thought to be a problem or do we just live with it? I don't recall hearing it for the first 3 months I owned the car, but again, maybe it was there just muted as the temperature was much higher?
I use OBD11 and it shows "charging" when the sound comes on.
#17
Same thing here with my 2017 A4 Premium Plus Quattro. Amazed that I could actually here it at my young age Tech at the dealership must have thought I was crazy because he couldn't hear it at all. Definitely think Audi should remedy this while under warranty. Any status updates much appreciated and glad to know that I am not alone.
Best,
Dtownav8tor
Best,
Dtownav8tor
#18
Best,
Dtownav8tor
Best,
Dtownav8tor
Regarding this noise.....There is a long thread about it here https://www.audiworld.com/forums/a4-...2914541/page7/
I had this noise as well, and after several attempts with the service agent I finally got it fixed! Please see the above thread, (there is some information and misinformation) but if you listen to the videos and audio files I posted you will see that we are talking about the same noise... and my very last entry with the solution that worked for me here in Australia. There is a software update. My B9 is now completely noise free on the down shifts and I don't need the music on at all Hope this is of some help to anyone with this annoying noise.
Kind regards
avss01
#19
Hi all
Kind regards
avss01
Kind regards
avss01
my sound
#20
To update where i'm at... my sound is different from the one @mykohph and @avss01 in the other post have mentioned. It is exactly the one that @StuartWes posted in the other post.
I talked to my dealer at the 10k service but they couldn't replicate it. They asked me to catch it on video, which I have done and sent to them. Waiting for a reply to them.
The video I made is here: https://photos.app.goo.gl/pTGahcCoEE1B9pHr7
The noise really starts up about 1:40 in. Sorry in advance if you watch for having to look at my ugly gams... just wanted to get my phone close to the floor for optimum pickup.
