2.8 30V Valve Tapping
B4 I get started, YES I have searched the forums and have not found information to satisfy my concerns.
Sure, it taps at start up. But I have noticed that I can hear a faint tapping at low speeds/high rpms, say when driving in first gear in a parking lot or something.
I had an Acura Legend which developed the same problem... at 150,000+ miles due to dirty valve lifters. The A4 has <50,000.
My question is, is THIS a common problem along with the cold start? or is this just an 'effect' of driving an aging 5v motor? should I feed it Restore, as I did the Legend? Switch oil weight?
Experienced/knowledgable advice is prefered.
added notes: 99.5 A4 Quattro, Manual Trans, bought at 42k miles, now has 47ish. Using 5W-30. Cold climate. Last oil change less than 1000mi ago.
Re: 2.8 30V Valve Tapping
search under ticking sound.
most suggest:
1. oil detergent drive it for 1.5K
2. switch to synthetic oil
I have around 37K, it only happens after a long drive (oil viscosity is thinner). Doing 1 and 2 will help that problem.
and yes is normal for these 5V motors.
most suggest:
Is this only in the cold?
My engine quieted down a lot switching from 15W40 to 5W30 synth. Seems like you're already there, but in the extreme cold of the past week, 0W30 or 0W40 may be a better choice.
I'm neither knowledgeable or experienced, however
a6wag
Audi 100 / A6 (C4 Platform)
11-05-2008 06:24 AM
Avanthead
08-09-2008 08:37 PM
Shabbis
08-31-1999 10:08 AM
