ABS Problem?
Old Jun 15, 2003 | 01:26 PM
ULuvItBch's Avatar
New Member
Default ABS Problem?
I replaced my wheels and rotors last week Now when coming to a stop, (Around 1-2 mph) it feels like my ABS kicks in. Even if I'm not pushing the brake, but am coming to a crawling stop, you can hear it kick in.
I didn't have to remove the sensors in the front when changing my rotors, but I did have to remove and put the rear sensors into the new rear rotors. My question is, if the rear sensors are not seated properly, could it possibly cause the problem I'm having? Would a VAG COM be able to see anything with the braking system?
f3d's Avatar
f3d
AudiWorld Uber User
short in a sensor maybe....
Old Jun 15, 2003 | 02:26 PM
SugarRushAudi's Avatar
Junior Member
Default i had it b4, abs sensor dirty or (more)
.. check your abs sensor,
it is probably clogged/dirty with muds/grease when you replaced it.clean it.
or the cable/wire to tbe sensor is damaged
fix this by replacing wire if resistance is infinte (continuity test)
or wire is clipped/bend by something when you put in the rotor. Just put it back properly.
in anyway, you have to take off the wheel to get to the sensor
Old Jun 15, 2003 | 05:42 PM
ULuvItBch's Avatar
New Member
Thanks, SugarRush. I'll be sure to check those out.
Mark1.8T
Feb 1, 2009 05:21 PM
ssainani
Jul 29, 2006 08:51 AM
Kirk
Canadian Discussion
May 13, 2005 06:03 AM
marcodant
Oct 28, 2004 03:03 PM
SLAB
Nov 29, 2003 02:55 AM
