Alarm Fuse? is there such thing?
Old Sep 20, 2005 | 06:10 AM
JohnelP's Avatar
Default Alarm Fuse? is there such thing?
I have the alarm on; and maybe the door switch does not clear it, cause the alarm remaines ON.
Now, as I have my started blocked by the alarm, a mechanic told me to remove the fuse of the alarm.
Is there such thing?
Is there any diagram with the fuses for a 1997 Audi A4 1.8T?
Old Sep 20, 2005 | 06:14 AM
jguthrie's Avatar
Default Wouldn't that defeat the whole purpose of the alarm
or am I not understanding the situation correctly. A fuse that, when removed, turns off the alarm and lets you start the car?
Anyways have you tried turning off the alarm by using the key in the other door or trunk?
Old Sep 20, 2005 | 06:23 AM
slightly disgruntled's Avatar
Default Yes. It does not make sense. I'd expect that a fuse disabling the alarm would disable the rest of ..
the car, too, but I didn't design it.
Old Sep 20, 2005 | 06:39 AM
BigEd's Avatar
Member
Sure. Fuse #224 (alarm system and anti-theft engine disable fuse) on the left side of the dash
Old Sep 20, 2005 | 06:51 AM
Does the alarm disable the engine, when it goes off?
Old Sep 20, 2005 | 07:08 AM
BigEd's Avatar
Member
don't know. Bentley isn't specific, might need to check the manual
Old Sep 20, 2005 | 07:12 AM
JohnelP's Avatar
Default Re: Yes. It does not make sense. I'd expect that a fuse disabling the alarm would disable the rest o
It seemed to me weird as well.......
Yes, that makes the car much easier to be stolen, but at least this is what a "service advisor" from Audi told me. Turn the key in the passanger lock (here might be the problem because a "specialist mechanic" worked at the door lock) or at the ignition switch (also a possible point of failure because "another specialist" changed the ignition switch - while breaking the turn signal coloumn.... but that's adifferent story).
Since none of the above sugestions worked, he told me about the fuse.
cabbiegirl
Nov 23, 2008 01:33 PM
doobiesdaddy
2.7T V6 Discussion
Aug 7, 2008 02:03 PM
aca
Feb 19, 2007 08:34 AM
91audi90
12
Oct 10, 2004 07:01 AM
mph1985
Jan 18, 2004 06:03 AM
