any advantage or disadvantage with running 710N on stock boost?
is it better to run the regular 710 or 710n on stock boost? i've searched and found that the 710n requires more vacuum to open. would this be affected by stock boost?
No matter how much boost you run......
its not gonna change how much vacuum your engine makes, unless you blow it up. If you're running stock boost theres probably no reason to run a 710n.
Shouldn't be....
other than the valve not opening as often or soon as it should, and causing air to get forced back into the turbo, but this probably wont happen, a healthy motor pulls plenty of vacuum, you shouldnt worry.
Redrum14
11-15-2007 01:11 PM
A4Graham
07-15-2006 03:06 PM
how much boost should i run w/ a greddy boost oh yeah i have stock ko3's but stage2 plus!!!!!!!!!!!!
~DonQPremiumTequila~
9
01-15-2004 02:51 PM
QGMika
Performance and Tuning
9
03-19-2003 01:34 PM
