Any new info on M2000 1.8T changes to computer? Dyno results?
Guest
Posts: n/a
There seemed to be some people indicating that the 2000 model year had the the boost increased to as much as 8PSI (or more)... and also that the timing and/or fuel map might have been changed. Has anyone put the 2000 on a Dynojet and found out how much power it is putting out? I am kind of curious about this... I wonder if the engine is borrowing from the TT's fuel map and turbo settings.
Guest
Posts: n/a
Re: Any new info on M2000 1.8T changes to computer? Dyno results?
I've heard there is slightly more boost, but the throttle-by-wire ECU also gives more timing advance. I don't know if thats true though.
Something is up, 'cause my stock '00 A4 is running much faster than any stock <99.5 I've been in. I've timed it at 6.92 secs 0-60 on the gtech pro, and regularly run 7.0-7.1 without abusing it.
I'm curious if chipping the 2000 will see as big of an increase since it looks like Audi may have turned up the wick at the factory.
-Dave
'00 1.8TQMS
-Dave
'00 1.8TQMS
Guest
Posts: n/a
Wow, I think it would have to be making at least 170 bhp to pull those numbers (more)
My 97 GS-R (170 hp) was doing right around 7 seconds, and that's a car that weighs over 500 lbs LESS than the Audi.... I know that the Audi has more torque and is geared better but I don't see how it could pull those numbers without making substantially more power than the claimed 150 hp.
Guest
Posts: n/a
The answer may be low driveline loss
I've heard it suggested that the B5's very low driveline loss (I've seen as little as 8% claimed) result in the car being significantly faster than crank hp numbers indicate. This may also explain why tuners sometimes claim extra-high hp and torque numbers for their chips, and when called on it, claim that the stock car they tested had 170 hp or 179 lb-ft of torque.
Guest
Posts: n/a
Re: Wow, I think it would have to be making at least 170 bhp to pull those numbers (more)
Denver,
We also have a 97 Integra GSR, which I have at least 10K miles driving in....problem with the GSR is it spins the tires like crazy at launch. You cant get a clean start without losing lots of time as you drop below VTEC-range. We've gotten 7.0-7.2's on it.
The GSR is a fun car, would be a blast on the track. But around town, its got poor ergonomics, dangerous visibility, twitchy handling, and a civic interior. Typical bulletproof reliability though, and 32mpg.
I'm trying to talk the wife into a 323is as the next car. She wants a Yellow S4 now though :-)
-Dave
-Dave
just curious
12-05-1999 04:43 PM
Garrett Lim GIAC
11-16-1999 06:43 AM
