Anyone have a pic for the right direction for BPV install . . .
No pic but it is fairly easy to see which is which. You want the end directly opposite the small vac
hose to be in the hose that runs up to the intake hose. This puts the bottom of the diaphram away from the boost pressure and the side port (side of the diaphram) toward the boost pressure.
Re: Anyone have a pic for the right direction for BPV install . . .
if it is put in backwards woulud you still get full boost? just curious never really thought bout what would happen if one was put in backwards
Depending on the boost pressure you can either blow it open or tear the diaphram if you have boo
so either way it would fail? i had a friend help me put one in at the end of last year never thought of what direction it should go, but i have a boost gauge and still have full boost so i'm assuming its correct.
